[petsc-dev] freebsd breakage
    Satish Balay
    balay at mcs.anl.gov
    Tue Sep  8 11:23:32 CDT 2015
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/configure_next_arch-freebsd-cxx-pkgs-opt_wii.log
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/configure_next_arch-freebsd-pkgs-opt_wii.log
https://bitbucket.org/petsc/petsc/commits/e1450d8053bc869c6cfb945a2ea6dba10cadf607 is triggering this.
sept-3: ================================================================================
TEST checkSharedLinker from config.setCompilers(/usr/home/balay/petsc.clone-2/config/BuildSystem/config/setCompilers.py:1246)
TESTING: checkSharedLinker from config.setCompilers(/usr/home/balay/petsc.clone-2/config/BuildSystem/config/setCompilers.py:1246)
  Check that the linker can produce shared libraries
Executing: uname -s
stdout: FreeBSD
                              Checking shared linker /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicxx using flags ['-shared']
Checking for program /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicxx...found
                                  Defined make macro "LD_SHARED" to "/usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicxx"
Executing: /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicc -c -o /tmp/petsc-GagEyB/config.setCompilers/conftest.o -I/tmp/petsc-GagEyB/config.compilers -I/tmp/petsc-GagEyB/config.utilities.closure -I/tmp/petsc-GagEyB/config.headers -I/tmp/petsc-GagEyB/config.utilities.cacheDetails -I/tmp/petsc-GagEyB/config.types -I/tmp/petsc-GagEyB/config.atomics -I/tmp/petsc-GagEyB/config.utilities.getResidentSetSize -I/tmp/petsc-GagEyB/config.libraries -I/tmp/petsc-GagEyB/config.utilities.featureTestMacros -I/tmp/petsc-GagEyB/config.utilities.missing -I/tmp/petsc-GagEyB/config.setCompilers -I/tmp/petsc-GagEyB/config.functions  -fPIC  /tmp/petsc-GagEyB/config.setCompilers/conftest.c
Successful compile:
sept-8: ================================================================================
TEST checkSharedLinker from config.setCompilers(/usr/home/balay/petsc.clone-2/config/BuildSystem/config/setCompilers.py:1263)
TESTING: checkSharedLinker from config.setCompilers(/usr/home/balay/petsc.clone-2/config/BuildSystem/config/setCompilers.py:1263)
Executing: uname -s
stdout: FreeBSD
Executing: /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicc -c -o /tmp/petsc-xTFsod/config.setCompilers/conftest.o -I/tmp/petsc-xTFsod/config.compilers -I/tmp/petsc-xTFsod/config.utilities.closure -I/tmp/petsc-xTFsod/config.headers -I/tmp/petsc-xTFsod/config.utilities.cacheDetails -I/tmp/petsc-xTFsod/config.types -I/tmp/petsc-xTFsod/config.atomics -I/tmp/petsc-xTFsod/config.utilities.getResidentSetSize -I/tmp/petsc-xTFsod/config.libraries -I/tmp/petsc-xTFsod/config.utilities.featureTestMacros -I/tmp/petsc-xTFsod/config.utilities.missing -I/tmp/petsc-xTFsod/config.setCompilers -I/tmp/petsc-xTFsod/config.functions   /tmp/petsc-xTFsod/config.setCompilers/conftest.c
Successful compile:
So the -fPIC is missing from the sep-8 compile - triggering this issue?
Satish
