[petsc-dev] Open solaris 64bit printf bug?
Barry Smith
bsmith at mcs.anl.gov
Thu Sep 3 22:56:54 CDT 2015
> On Sep 3, 2015, at 10:52 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> I couldn't get this build [with 64-bit-indices] compiled in debug
> mode. The compiler just hangs with a couple of source files.
> CC arch-opensolaris-misc/obj/src/mat/impls/aij/seq/inode.o
> CC arch-opensolaris-misc/obj/src/dm/impls/da/fdda.o
> I had to manaully compile these sources with '-O' - instead of '-g' to
> get the build going :(
I noticed that same hang but wasn't bright enough to try removing the -g on them.
We use to have trouble with compilers with optimization turned on, now we have trouble with optimization turned off!
Barry
> Satish
> On Thu, 3 Sep 2015, Barry Smith wrote:
>> And just to annoy me I cannot get -start_in_debugger to work on that machine. Valgrind has no complaints on a Mac with the examples.
>> I've found some miss-use of PetscViewerASCIIPushSynchronized() and %d in parts of plex, I don't see how they could cause this problem but I am fixing them and will push that. Maybe we'll get lucky.
>> Barry
>>> On Sep 3, 2015, at 10:06 AM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
>>> Here's a partial diff from http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/03/examples_next_arch-opensolaris-misc_n-gage.log:
>>> 232c232
>>> < field 0 with 2 components
>>>> field 0 with 0 components
>>> 234,242c234,242
>>> < ( 2) dim 2 offset 0 0.5 0
>>> < ( 3) dim 2 offset 2 1 0
>>> < ( 4) dim 2 offset 4 0 0.5
>>> < ( 5) dim 2 offset 6 0.5 0.5
>>> < ( 6) dim 2 offset 8 1 0.5
>>> < ( 7) dim 2 offset 10 0 1
>>> < ( 8) dim 2 offset 12 0.5 1
>>> < ( 9) dim 2 offset 14 0.5 0.25
>>> < ( 10) dim 2 offset 16 0.25 0.5
>>>> ( 2) dim 0 offset 2 0.5 0
>>>> ( 3) dim 0 offset 2 1 0
>>>> ( 4) dim 0 offset 2 0 0.5
>>>> ( 5) dim 0 offset 2 0.5 0.5
>>>> ( 6) dim 0 offset 2 1 0.5
>>>> ( 7) dim 0 offset 2 0 1
>>>> ( 8) dim 0 offset 2 0.5 1
>>>> ( 9) dim 0 offset 2 0.5 0.25
>>>> ( 10) dim 0 offset 2 0.25 0.5
>>> The numbers that printf is making 0 (or 2) clearly aren't, because
>>> they are used to iterate over a section and display its contents. But
>>> other PetscInt's are printed fine elsewhere. Weird.
>>> Toby
