[petsc-dev] Open solaris 64bit printf bug?
    Tobin Isaac
    tisaac at ices.utexas.edu
    Thu Sep  3 10:06:40 CDT 2015
Here's a partial diff from http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/03/examples_next_arch-opensolaris-misc_n-gage.log:
    232c232
    <   field 0 with 2 components
    >   field 0 with 0 components
    234,242c234,242
    <   (   2) dim  2 offset   0 0.5 0
    <   (   3) dim  2 offset   2 1 0
    <   (   4) dim  2 offset   4 0 0.5
    <   (   5) dim  2 offset   6 0.5 0.5
    <   (   6) dim  2 offset   8 1 0.5
    <   (   7) dim  2 offset  10 0 1
    <   (   8) dim  2 offset  12 0.5 1
    <   (   9) dim  2 offset  14 0.5 0.25
    <   (  10) dim  2 offset  16 0.25 0.5
    >   (   2) dim  0 offset   2 0.5 0
    >   (   3) dim  0 offset   2 1 0
    >   (   4) dim  0 offset   2 0 0.5
    >   (   5) dim  0 offset   2 0.5 0.5
    >   (   6) dim  0 offset   2 1 0.5
    >   (   7) dim  0 offset   2 0 1
    >   (   8) dim  0 offset   2 0.5 1
    >   (   9) dim  0 offset   2 0.5 0.25
    >   (  10) dim  0 offset   2 0.25 0.5
The numbers that printf is making 0 (or 2) clearly aren't, because
they are used to iterate over a section and display its contents.  But
other PetscInt's are printed fine elsewhere.  Weird.
  Toby
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150903/0790e867/attachment.sig>
