[petsc-dev] problems with shared libraries and pragmatic.py
Jed Brown
jed at jedbrown.org
Thu Oct 15 16:08:31 CDT 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
>> What is lib pragmatic?
> I have no idea, but it is in PETSc so needs to be tested or deleted.
Wow, those Imperial guys sure have a way with language.
PRAgMaTIc (Parallel anisotRopic Adaptive Mesh ToolkIt)
https://github.com/meshadaptation/pragmatic
>> Can you include the verbose link line for
>> libpetsc.dylib? (Delete it and "make V=1".)
> $ make V=1 gnumake
> Building PETSc using GNU Make with 7 build threads
I don't see anything weird here. It seems exactly analogous to
libparmetis.dylib, but something (evidently not in the link line) is
causing it to be treated differently. Secret Apple "feature"?
> BTW: pragmatic is built with cmake, could that be messing it up somehow?
Conceivably, if it is somehow linked in a different way from
libparmetis.dylib.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151015/b9de4846/attachment.sig>
