[petsc-dev] Mac OS X El Capitan does not propagate DYLD_LIBRARY_PATH from parent process
    Satish Balay
    balay at mcs.anl.gov
    Wed Oct  7 17:09:04 CDT 2015
On Wed, 7 Oct 2015, Andrs, David wrote:
> As I said before the fix here is to link libomp.dylib using the absolute
> path, i.e. we need to do something on our end. It is not a bug in PETSc's
> build system. I just wanted to give you guys a heads up, because some users
> might run into a similar issue...
BTW: what do you have for 'mpicc -show'
[configure.log you sent earlier didn't get far enough to caputure that]
also good to know:
mpicc -v foo.c [on any test code]
Satish
