[petsc-dev] Mac OS X El Capitan does not propagate DYLD_LIBRARY_PATH from parent process
Satish Balay
balay at mcs.anl.gov
Wed Oct 7 17:06:59 CDT 2015
Ok - works with homebrew [which installs to /usr/local] if python is
explicitly used [i.e without #!/usr/bin/env]
Satish
balay at imav^~/junk $ export FOOBAR=foobar
balay at imav^~/junk $ export DYLD_LIBRARY_PATH=foobar
balay at imav^~/junk $ which python
/usr/local/bin/python
balay at imav^~/junk $ cat env-test.py
#!/usr/bin/env python
import os
if 'FOOBAR' in os.environ:
print 'FOOBAR:', os.environ['FOOBAR']
else:
print 'FOOBAR not in env'
if 'DYLD_LIBRARY_PATH' in os.environ:
print 'DYLD_LIBRARY_PATH:', os.environ['DYLD_LIBRARY_PATH']
else:
print 'DYLD_LIBRARY_PATH not in env'
balay at imav^~/junk $ ./env-test.py
FOOBAR: foobar
balay at imav^~/junk $ python ./env-test.py
FOOBAR: foobar
DYLD_LIBRARY_PATH: foobar
On Wed, 7 Oct 2015, Munson, Todd S. wrote:
> It seems that "core" stuff is anything located in one of the protected directories.
> Macports puts everything in /opt, which is not protected by SIP. So, if you use
> all the macport utilities and bypass all executables in /usr, then in theory
> you should be fine.
> > On Oct 7, 2015, at 4:45 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Presumably you could also install the latest python download (not from Apple) and it won't have this "protection".
