[petsc-dev] Mac OS X El Capitan does not propagate DYLD_LIBRARY_PATH from parent process
Mon Oct 5 10:20:56 CDT 2015
Thanks for the note.
This sounds more like a 'broken compiler' issue.
PETSc buildsystem attempts to not rely on DYLD_LIBRARY_PATH.
i.e whenever possible - it converts all '-L/foo to '-L/foo
-Wl,-rpath,/foo' in the link line.
However if 'mpicc/cc' is provided - it assumes it works - and doesn't
try to detect its internal libs - so it won't add -Wl-rpath to such
internal paths - so its likely to fail with mpicc that relies on
DYLD_LIBRARY_PATH
[Workarround is to add 'LIBS=-Wl,/foo' option to configure]
I had recently run --download-mpich build [with default compilers] on
'El Capitan' - and that ran fine.
BTW: is libiomp5.dylib a clang library? [normally I see this with intel compiler]
Also - could you send us the configure.log for a build that breaks with it?
[so that we can see what exactly breaks on El..]
Satish
On Mon, 5 Oct 2015, Andrs, David wrote:
> Hi guys!
> If you are not aware of this yet, DYLD_LIBRARY_PATH does not get propagated
> into the child processes on El Capitan. See
> https://forums.developer.apple.com/message/31148
> I am not sure if that has some implications for your build system, but we
> were not able to build PETSc because one of our libraries (libiomp5.dylib)
> relied on it and the build system failed detecting the compiler (we ship
> our version of clang with MOOSE).
> I know, it is not a build system issue, it is how we build some underlying
> piece. I just wanted to make you are aware of this.
> David
