[petsc-dev] Requiring $prefix/lib for --with-pkg-dir=
Satish Balay
balay at mcs.anl.gov
Wed Mar 18 00:37:41 CDT 2015
For one - I want to get rid of 'self.libdir,self.altlibdir' usage [but
self.libdir is used allover configure - so I should look at this usage
more closely before I make this change].
But to adress your issue - I expected packages that don't have 'lib' to
set: [as in config/BuildSystem/config/packages/cusp.py]
self.libdir = ''.
But to get libdir check working for mpicc etc - perhaps the following would
suffice?
$ git diff config/BuildSystem/config/packages/MPI.py
diff --git a/config/BuildSystem/config/packages/MPI.py b/config/BuildSystem/config/packages/MPI.py
index 0a0cb2a..312de0c 100644
--- a/config/BuildSystem/config/packages/MPI.py
+++ b/config/BuildSystem/config/packages/MPI.py
@@ -68,6 +68,7 @@ class Configure(config.package.Package):
def generateLibList(self, directory):
if self.setCompilers.usedMPICompilers:
self.liblist = []
+ self.libdir = []
return config.package.Package.generateLibList(self,directory)
# search many obscure locations for MPI
To get this working more generally - perhaps the following change?
$ git diff config/BuildSystem/config/package.py |cat
diff --git a/config/BuildSystem/config/package.py b/config/BuildSystem/config/package.py
index 4c1f2c4..7a7da1b 100644
--- a/config/BuildSystem/config/package.py
+++ b/config/BuildSystem/config/package.py
@@ -322,7 +322,7 @@ class Package(config.base.Configure):
def generateGuesses(self):
d = self.checkDownload()
if d:
- for libdir in [self.libdir, self.altlibdir]:
+ for libdir in [self.libdir, self.altlibdir, '']:
libdirpath = os.path.join(d, libdir)
if not os.path.isdir(libdirpath):
self.logPrint(self.PACKAGE+': Downloaded DirPath not found.. skipping: '+libdirpath)
@@ -358,7 +358,7 @@ class Package(config.base.Configure):
fakeExternalPackagesDir+' is reserved for --download-package scratch space. \n'+
'Do not install software in this location nor use software in this directory.')
self.logPrint(self.PACKAGE+': UserSpecified DirPath not found.. skipping: '+libdirpath)
@@ -405,7 +405,7 @@ class Package(config.base.Configure):
self.logPrint(self.PACKAGE+': SearchDir DirPath not found.. skipping: '+d)
continue
includedir = self.getIncludeDirs(d, self.includedir)
self.logPrint(self.PACKAGE+': DirPath not found.. skipping: '+libdirpath)
Satish
On Mon, 16 Mar 2015, Jed Brown wrote:
> As of this commit, --with-mpi-dir=/prefix requires that /prefix/lib
> exists. I use ccache so this doesn't exist, but some packages don't
> have/need $prefix/lib anyway. (I got a working build by creating an
> empty lib directory.)
> Can we get relax this check or at the very least give an error message
> that explains why we're failing?
> commit 4d3c5e81ae5a13470b170f68287cb1ab351ca05d
> Author: Satish Balay <balay at mcs.anl.gov>
> Date: Wed Feb 25 22:13:09 2015 -0600
> configure: skip non-existant dirs in generateGuesses()
