[petsc-dev] VecView problem in fortran
Adrian Croucher a.croucher at auckland.ac.nz
Mon Mar 16 20:00:01 CDT 2015
hi,
The attached minimal C test program to create a Vec and view it produces
the output I expect:
acro018 at des108:~/software/PETSc/tests/dmda$ mpirun -np 2 testc
Vec Object: 2 MPI processes
   type: mpi
Process [0]
0
0
0
0
0
Process [1]
0
0
0
0
0
But the attached Fortran program, which I thought should do the same,
produces no output at all. Am I missing something? I'm running 'next'
branch.
Cheers, Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 84611
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150317/db8e627e/attachment.bin>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150317/db8e627e/attachment-0001.bin>
