[petsc-dev] more automatic notification of errors in nightly builds
    Satish Balay
    balay at mcs.anl.gov
    Fri Mar 13 16:42:10 CDT 2015
Added to the nightly cronjob for master and next build logs. [and
pushed a couple of changes]
Satish
On Wed, 4 Mar 2015, Barry Smith wrote:
>   Toby,
>     Wow, this is great! Thanks  (I pushed some trivial changes)
>    Satish,
>       Can you rig this up to run each morning after 9 am on the next builds automatically sending the email.
>      We can do more fine tuning of the script as time goes by but let's get it out there and tested.
>    Thanks
>      Barry
> > On Mar 4, 2015, at 11:17 AM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
> > On Mon, Mar 02, 2015 at 02:05:49PM -0600, Barry Smith wrote:
> >>> On Mar 2, 2015, at 1:59 PM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
> >>> Slightly off topic: if/when the jenkins-ci testing gets off the
> >>> ground, can we pipe compiler warnings through git blame to automate
> >>> sending messages to responsible parties?
> >>   This is independent of the jenkins-ci testing. If you provide the logic this can be done now in nightly builds. I would welcome this logic.
> > I've got a branch 'tisaac/check-build-blame' that puts this logic in
> > checkBuild.py.  I made local copies of last nights logs and tested
> > them out with
> > ./bin/maint/checkBuilds.py -blameMail -ignoreNote -ignoreDeprecated
> > It doesn't send the mail, but it generates the messages for review.
> > There are some obvious flaws with this approach (Karl gets blamed for
> > running uncrustify, the mswin compilers choke on a lot of things), but
> > otherwise it works about as expected.
> >  Toby
> >> Barry
> >>> Toby
> >>> On Mon, Mar 02, 2015 at 01:21:39PM -0600, Barry Smith wrote:
> >>>> ---- WARNINGS ----
> >>>> /sandbox/petsc/petsc.clone-2/src/dm/impls/plex/plexsubmesh.c:1575:17: warning: absolute value function 'abs' given an argument of type 'PetscInt' (aka 'long') but has parameter of type 'int' which may cause truncation of value [-Wabsolute-value]
> >>>> 1 warning generated.
