[petsc-dev] more automatic notification of errors in nightly	builds
    Tobin Isaac
    tisaac at ices.utexas.edu
    Wed Mar  4 22:20:39 CST 2015
On Wed, Mar 04, 2015 at 10:17:33PM -0600, Barry Smith wrote:
> > On Mar 4, 2015, at 10:09 PM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
> > On Wed, Mar 04, 2015 at 06:00:55PM -0600, Barry Smith wrote:
> >>  Toby,
> >>    Wow, this is great! Thanks  (I pushed some trivial changes)
> >>   Satish,
> >>      Can you rig this up to run each morning after 9 am on the next builds automatically sending the email.
> >>     We can do more fine tuning of the script as time goes by but let's get it out there and tested.
> > I would also make the `-ignoreNote` option default: gcc-like warnings
> > often include `note:`s pointing to other lines that don't have any
> > faults in them, and I didn't come up with a good way of attaching
> > these to the original warnings.
>   I had hoped by leaving them there it would motivate us all to improve the script to handle them properly :-)
Can I rename the feature branch to tisaac/open-pandoras-box ?
> > Also IMO sending the emails automatically could be counterproductive.
> > If a warning caused by John is misattributed to Jane, only she gets
> > the email, and she gets it every day until she (a) brings it to the
> > attention of someone who can fix it, or (b) starts ignoring the
> > emails, which defeats their intended purpose.
>    Could be, but we won't know without trying for a while. And even if it makes Matt fix 50% of the plex problems it will have served its purpose :-)
> Barry
> >  Toby
> >>   Thanks
> >>     Barry
> >>> On Mar 4, 2015, at 11:17 AM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
> >>> On Mon, Mar 02, 2015 at 02:05:49PM -0600, Barry Smith wrote:
> >>>>> On Mar 2, 2015, at 1:59 PM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
> >>>>> Slightly off topic: if/when the jenkins-ci testing gets off the
> >>>>> ground, can we pipe compiler warnings through git blame to automate
> >>>>> sending messages to responsible parties?
> >>>>  This is independent of the jenkins-ci testing. If you provide the logic this can be done now in nightly builds. I would welcome this logic.
> >>> I've got a branch 'tisaac/check-build-blame' that puts this logic in
> >>> checkBuild.py.  I made local copies of last nights logs and tested
> >>> them out with
> >>> ./bin/maint/checkBuilds.py -blameMail -ignoreNote -ignoreDeprecated
> >>> It doesn't send the mail, but it generates the messages for review.
> >>> There are some obvious flaws with this approach (Karl gets blamed for
> >>> running uncrustify, the mswin compilers choke on a lot of things), but
> >>> otherwise it works about as expected.
> >>> Toby
> >>>> Barry
> >>>>> Toby
> >>>>> On Mon, Mar 02, 2015 at 01:21:39PM -0600, Barry Smith wrote:
> >>>>>> ---- WARNINGS ----
> >>>>>> /sandbox/petsc/petsc.clone-2/src/dm/impls/plex/plexsubmesh.c:1575:17: warning: absolute value function 'abs' given an argument of type 'PetscInt' (aka 'long') but has parameter of type 'int' which may cause truncation of value [-Wabsolute-value]
> >>>>>> 1 warning generated.
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150304/a462cc8d/attachment.sig>
