[petsc-dev] Configure problem on Titan
    Eric Bavier
    bavier at cray.com
    Wed Mar 11 17:00:31 CDT 2015
It looks like you are building with the PGI compilers.  Try adding:
--CXX_LINKER_FLAGS="-Meh_frame -lstdc++"
to your petsc configure flags.
Hope that helps,
`~Eric Bavier, Scientific Libraries, Cray Inc.
From: petsc-dev-bounces at mcs.anl.gov [petsc-dev-bounces at mcs.anl.gov] on behalf of Satish Balay [balay at mcs.anl.gov]
Sent: Wednesday, March 11, 2015 16:55
To: Mark Adams
Cc: For users of the development version of PETSc
Subject: Re: [petsc-dev] Configure problem on Titan
Executing: ftn  -o /tmp/scratch/petsc-5_JlCR/config.compilers/conftest    -mp -fast  /tmp/scratch/petsc-5_JlCR/config.compilers/conftest.o /tmp/scratch/petsc-5_JlCR/config.compilers/cxxobj.o  /tmp/scratch/petsc-5_JlCR/config.compilers/confc.o  -ldl
Possible ERROR while running linker: exit code 512
stderr:
/tmp/scratch/petsc-5_JlCR/config.compilers/cxxobj.o:(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
/tmp/scratch/petsc-5_JlCR/config.compilers/confc.o:(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
/usr/bin/ld: link errors found, deleting executable `/tmp/scratch/petsc-5_JlCR/config.compilers/conftest'
Perhaps the compilers are not setup correctly after the update?
If you don't need c++ - you can try building with --with-cxx=0 configure option..
satish
On Wed, 11 Mar 2015, Mark Adams wrote:
> I am getting this error on Titan.  They just had a big PM and it was
> recommended that we rebuild everything
