[petsc-dev] Configure problem on Titan
Satish Balay
balay at mcs.anl.gov
Wed Mar 11 16:55:08 CDT 2015
Executing: ftn -o /tmp/scratch/petsc-5_JlCR/config.compilers/conftest -mp -fast /tmp/scratch/petsc-5_JlCR/config.compilers/conftest.o /tmp/scratch/petsc-5_JlCR/config.compilers/cxxobj.o /tmp/scratch/petsc-5_JlCR/config.compilers/confc.o -ldl
Possible ERROR while running linker: exit code 512
stderr:
/tmp/scratch/petsc-5_JlCR/config.compilers/cxxobj.o:(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
/tmp/scratch/petsc-5_JlCR/config.compilers/confc.o:(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
/usr/bin/ld: link errors found, deleting executable `/tmp/scratch/petsc-5_JlCR/config.compilers/conftest'
Perhaps the compilers are not setup correctly after the update?
If you don't need c++ - you can try building with --with-cxx=0 configure option..
satish
On Wed, 11 Mar 2015, Mark Adams wrote:
> I am getting this error on Titan. They just had a big PM and it was
> recommended that we rebuild everything
