[petsc-dev] Patch for ksp tutorial ex56
    Hong
    hzhang at mcs.anl.gov
    Tue Mar 10 15:28:57 CDT 2015
Sascha :
Thanks for your contribution!
I have patched both to petsc-master in the branch hzhang/ex-update
https://bitbucket.org/petsc/petsc/commits/0c500c50befac1baa76f423dafbb038fecb748c3
Once it passes our regression tests, I'll merge it to the petsc master.
Hong
Hello,
> I prepared a patch regarding the reading of the data file in ksp tutorial
> ex56.
> It sets the path to the data file required for running the example
> relative to PETSC_DIR
> instead of relative to the tutorials folder to allow running the example
> from any folder.
> Also, I used PETSC_DIR_SEPARATOR instead of the currently hard coded ‘/‘
> so that the code would also run on a windows machine … if anyone cared.
> Please discard the patch if you do not want to change the current behavior.
> Best,
> Sascha
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150310/f4549bb0/attachment.html>
