[petsc-dev] Patch for ksp tutorial ex56
    Sascha Schnepp
    mail at saschaschnepp.net
    Tue Mar 10 13:27:11 CDT 2015
Hello,
I prepared a patch regarding the reading of the data file in ksp tutorial ex56.
It sets the path to the data file required for running the example relative to PETSC_DIR
instead of relative to the tutorials folder to allow running the example from any folder.
Also, I used PETSC_DIR_SEPARATOR instead of the currently hard coded ‘/‘
so that the code would also run on a windows machine … if anyone cared.
Please discard the patch if you do not want to change the current behavior.
Best,
Sascha
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150310/b7ea91fd/attachment.obj>
