[petsc-dev] more automatic notification of errors in nightly builds
Tobin Isaac
tisaac at ices.utexas.edu
Wed Mar 4 22:09:19 CST 2015
On Wed, Mar 04, 2015 at 06:00:55PM -0600, Barry Smith wrote:
> Toby,
> Wow, this is great! Thanks (I pushed some trivial changes)
> Satish,
> Can you rig this up to run each morning after 9 am on the next builds automatically sending the email.
> We can do more fine tuning of the script as time goes by but let's get it out there and tested.
I would also make the `-ignoreNote` option default: gcc-like warnings
often include `note:`s pointing to other lines that don't have any
faults in them, and I didn't come up with a good way of attaching
these to the original warnings.
Also IMO sending the emails automatically could be counterproductive.
If a warning caused by John is misattributed to Jane, only she gets
the email, and she gets it every day until she (a) brings it to the
attention of someone who can fix it, or (b) starts ignoring the
emails, which defeats their intended purpose.
Toby
> Thanks
> Barry
> > On Mar 4, 2015, at 11:17 AM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
> > On Mon, Mar 02, 2015 at 02:05:49PM -0600, Barry Smith wrote:
> >>> On Mar 2, 2015, at 1:59 PM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
> >>> Slightly off topic: if/when the jenkins-ci testing gets off the
> >>> ground, can we pipe compiler warnings through git blame to automate
> >>> sending messages to responsible parties?
> >> This is independent of the jenkins-ci testing. If you provide the logic this can be done now in nightly builds. I would welcome this logic.
> > I've got a branch 'tisaac/check-build-blame' that puts this logic in
> > checkBuild.py. I made local copies of last nights logs and tested
> > them out with
> > ./bin/maint/checkBuilds.py -blameMail -ignoreNote -ignoreDeprecated
> > It doesn't send the mail, but it generates the messages for review.
> > There are some obvious flaws with this approach (Karl gets blamed for
> > running uncrustify, the mswin compilers choke on a lot of things), but
> > otherwise it works about as expected.
> > Toby
> >> Barry
> >>> Toby
> >>> On Mon, Mar 02, 2015 at 01:21:39PM -0600, Barry Smith wrote:
> >>>> ---- WARNINGS ----
> >>>> /sandbox/petsc/petsc.clone-2/src/dm/impls/plex/plexsubmesh.c:1575:17: warning: absolute value function 'abs' given an argument of type 'PetscInt' (aka 'long') but has parameter of type 'int' which may cause truncation of value [-Wabsolute-value]
> >>>> 1 warning generated.
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150304/27ef206f/attachment.sig>
