[petsc-dev] more automatic notification of errors in nightly builds
Barry Smith
bsmith at mcs.anl.gov
Wed Mar 4 18:00:55 CST 2015
Toby,
Wow, this is great! Thanks (I pushed some trivial changes)
Satish,
Can you rig this up to run each morning after 9 am on the next builds automatically sending the email.
We can do more fine tuning of the script as time goes by but let's get it out there and tested.
Thanks
Barry
> On Mar 4, 2015, at 11:17 AM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
> On Mon, Mar 02, 2015 at 02:05:49PM -0600, Barry Smith wrote:
>>> On Mar 2, 2015, at 1:59 PM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
>>> Slightly off topic: if/when the jenkins-ci testing gets off the
>>> ground, can we pipe compiler warnings through git blame to automate
>>> sending messages to responsible parties?
>> This is independent of the jenkins-ci testing. If you provide the logic this can be done now in nightly builds. I would welcome this logic.
> I've got a branch 'tisaac/check-build-blame' that puts this logic in
> checkBuild.py. I made local copies of last nights logs and tested
> them out with
> ./bin/maint/checkBuilds.py -blameMail -ignoreNote -ignoreDeprecated
> It doesn't send the mail, but it generates the messages for review.
> There are some obvious flaws with this approach (Karl gets blamed for
> running uncrustify, the mswin compilers choke on a lot of things), but
> otherwise it works about as expected.
> Toby
>> Barry
>>> Toby
>>> On Mon, Mar 02, 2015 at 01:21:39PM -0600, Barry Smith wrote:
>>>> ---- WARNINGS ----
>>>> /sandbox/petsc/petsc.clone-2/src/dm/impls/plex/plexsubmesh.c:1575:17: warning: absolute value function 'abs' given an argument of type 'PetscInt' (aka 'long') but has parameter of type 'int' which may cause truncation of value [-Wabsolute-value]
>>>> 1 warning generated.
