[petsc-dev] failure of new parallel configure
Satish Balay
balay at mcs.anl.gov
Tue Mar 3 12:07:02 CST 2015
Right not most nightly builds are broken.
ftp://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/03/03/next.html
It might be the new parallel build has non-deterministic behaviror -
so issues will be harder to reproduce?
Perhaps this branch should be reverted from next until its stable?
Satish
A couple ofissues that can be reproduced:
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
1:
$ ./configure --useThreads=0
Configuring PETSc to compile on your system
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:832)
<hang>
2: python24 test:
balay at es^/scratch/balay/petsc(next=) $ ./config/examples/arch-linux-pkgs-opt.py
TESTING: configureExternalPackagesDir from config.framework(/scratch/balay/petsc/config/BuildSystem/config/framework.py:832)
TESTING: configureMkdir from config.programs(/scratch/balay/petsc/config/BuildSystem/config/programs.py:22)
TESTING: configureAutoreconf from config.programs(/scratch/balay/petsc/config/BuildSystem/config/programs.py:44)
TESTING: configurePrograms from config.programs(/scratch/balay/petsc/config/BuildSystem/config/programs.py:66)
CONFIGURATION CRASH (Please send configure.log to petsc-maint at mcs.anl.gov)
Exception in thread Thread-2:
Traceback (most recent call last):
File "/homes/petsc/soft/linux-Ubuntu_12.04-x86_64/Python-2.4.6/lib/python2.4/threading.py", line 442, in __bootstrap
self.run()
File "/homes/petsc/soft/linux-Ubuntu_12.04-x86_64/Python-2.4.6/lib/python2.4/threading.py", line 422, in run
self.__target(*self.__args, **self.__kwargs)
File "/scratch/balay/petsc/config/BuildSystem/config/framework.py", line 1012, in processChildren
q.task_done()
AttributeError: Queue instance has no attribute 'task_done'
On Mon, 2 Mar 2015, Matthew Knepley wrote:
> On Mon, Mar 2, 2015 at 7:45 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Oh fuck, never mind, if I get another crash I'll report it.
> Note that I am well aware that this is broken for > 1 thread. This is
> because we
> share the compiler/linker objects through the framework. I need to go
> through
> and fix that, which will get done soon.
> There are other potential breakages in the updating of framework data
> structures,
> but these are much less likely to cause problems, and are easily fixable. I
> have
> not seen these break when using a bunch of threads, unlike the above.
> Matt
> > Barry
> > > On Mar 2, 2015, at 6:50 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > > On Mon, Mar 2, 2015 at 6:24 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > > On Mar 2, 2015, at 6:06 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > > > Is this the latest? If not, can you run it after pulling?
> > > git reports already up to date
> > > This log looks like a success. Did you send the wrong one?
> > > Matt
> > > > Thanks,
> > > > Matt
> > > > On Mon, Mar 2, 2015 at 6:05 PM, Barry Smith <bsmith at mcs.anl.gov>
> > wrote:
> > > > $ ./configure --download-mpich --with-threadsafety --with-openmp
> > --with-log=0
> > Trying to download
> > http://www.mpich.org/static/downloads/3.1.3/mpich-3.1.3.tar.gz for MPICH
> > Trying to download
> > http://ftp.mcs.anl.gov/pub/petsc/externalpackages/mpich-3.1.3.tar.gz for
> > MPICH
> > Running configure on MPICH; this may take
> > several minutes
> > Running make on MPICH; this may take several
> > minutes
> > Running make install on MPICH; this may take
> > several minutes
> > TESTING: output from
> > config.setCompilers(config/BuildSystem/config/setCompilers.py:1451)
> > > > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
> > for details):
> > > > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which their
> > experiments lead.
> > > > -- Norbert Wiener
> > experiments lead.
> > > -- Norbert Wiener
