[petsc-dev] failure of new parallel configure
Matthew Knepley
knepley at gmail.com
Mon Mar 2 20:45:15 CST 2015
On Mon, Mar 2, 2015 at 7:45 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Oh fuck, never mind, if I get another crash I'll report it.
Note that I am well aware that this is broken for > 1 thread. This is
because we
share the compiler/linker objects through the framework. I need to go
through
and fix that, which will get done soon.
There are other potential breakages in the updating of framework data
structures,
but these are much less likely to cause problems, and are easily fixable. I
have
not seen these break when using a bunch of threads, unlike the above.
Matt
> Barry
> > On Mar 2, 2015, at 6:50 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Mon, Mar 2, 2015 at 6:24 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On Mar 2, 2015, at 6:06 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > > Is this the latest? If not, can you run it after pulling?
> > git reports already up to date
> > This log looks like a success. Did you send the wrong one?
> > Matt
> > > Thanks,
> > > Matt
> > > On Mon, Mar 2, 2015 at 6:05 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > $ ./configure --download-mpich --with-threadsafety --with-openmp
> --with-log=0
> > > Configuring PETSc to compile on your system
> Trying to download
> http://www.mpich.org/static/downloads/3.1.3/mpich-3.1.3.tar.gz for MPICH
> Trying to download
> http://ftp.mcs.anl.gov/pub/petsc/externalpackages/mpich-3.1.3.tar.gz for
> MPICH
> Running configure on MPICH; this may take
> several minutes
> Running make on MPICH; this may take several
> minutes
> Running make install on MPICH; this may take
> several minutes
> TESTING: output from
> config.setCompilers(config/BuildSystem/config/setCompilers.py:1451)
> > > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
> for details):
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150302/4582ad9d/attachment.html>
