[petsc-dev] Is someone screwing with the repo?
Tobin Isaac
tisaac at ices.utexas.edu
Wed Feb 25 17:36:59 CST 2015
Now I'm getting this error, but on a new branch...
On Wed, Feb 25, 2015 at 01:54:58PM -0600, Barry Smith wrote:
> I also got this message yesterday once. I deleted my local copy of the branch I was pushing, then pulled it, made my changes and then pushed it fine.
> A quick google indicates this is likely an issue with bitbucket being screwed up https://bitbucket.org/site/master/issue/11029/remote-error-insufficient-permission-for
> What is our backup plan for when bitbucket starts to suck?
> Barry
> > On Feb 25, 2015, at 8:28 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > knepley/feature-harmonic-advection *$:/PETSc3/petsc/petsc-dev$ git push
> > git push
> > Counting objects: 149, done.
> > Delta compression using up to 4 threads.
> > Compressing objects: 100% (35/35), done.
> > Writing objects: 100% (35/35), 4.60 KiB | 0 bytes/s, done.
> > Total 35 (delta 30), reused 0 (delta 0)
> > remote: error: insufficient permission for adding an object to repository database objects
> > remote: fatal: failed to write object
> > error: unpack failed: unpack-objects abnormal exit
> > To git at bitbucket.org:petsc/petsc
> > ! [remote rejected] knepley/feature-harmonic-advection -> knepley/feature-harmonic-advection (unpacker error)
> > error: failed to push some refs to 'git at bitbucket.org:petsc/petsc'
> > Matt
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150225/165d4e3f/attachment.sig>
