[petsc-dev] Is someone screwing with the repo?
Wed Feb 25 12:22:53 CST 2015
On Wed, Feb 25, 2015 at 10:20 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Is this issue repeatable? Can you verify your ssh key? [wrt whats on
> bitbucket account?]
Yes, I cannot push this branch. I can pull, so my SSH key is working.
> Also can you do a 'git fsck' in your repo? [I don't see a way to do the
> fsck on the remote repo]
I did
> I see a recent push from Toby - so some pushes are going through..
Not from me.
  Matt
> https://bitbucket.org/petsc/petsc
> Satish
> On Wed, 25 Feb 2015, Matthew Knepley wrote:
> > knepley/feature-harmonic-advection *$:/PETSc3/petsc/petsc-dev$ git push
> > git push
> > Counting objects: 149, done.
> > Delta compression using up to 4 threads.
> > Compressing objects: 100% (35/35), done.
> > Writing objects: 100% (35/35), 4.60 KiB | 0 bytes/s, done.
> > Total 35 (delta 30), reused 0 (delta 0)
> > remote: error: insufficient permission for adding an object to repository
> > database objects
> > remote: fatal: failed to write object
> > error: unpack failed: unpack-objects abnormal exit
> > To git at bitbucket.org:petsc/petsc
> >  ! [remote rejected] knepley/feature-harmonic-advection ->
> > knepley/feature-harmonic-advection (unpacker error)
> > error: failed to push some refs to 'git at bitbucket.org:petsc/petsc'
> >     Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150225/e4e497b3/attachment.html>
