[petsc-dev] Is someone screwing with the repo?
Satish Balay
balay at mcs.anl.gov
Wed Feb 25 10:20:15 CST 2015
Is this issue repeatable? Can you verify your ssh key? [wrt whats on bitbucket account?]
Also can you do a 'git fsck' in your repo? [I don't see a way to do the fsck on the remote repo]
I see a recent push from Toby - so some pushes are going through..
https://bitbucket.org/petsc/petsc
Satish
On Wed, 25 Feb 2015, Matthew Knepley wrote:
> knepley/feature-harmonic-advection *$:/PETSc3/petsc/petsc-dev$ git push
> git push
> Counting objects: 149, done.
> Delta compression using up to 4 threads.
> Compressing objects: 100% (35/35), done.
> Writing objects: 100% (35/35), 4.60 KiB | 0 bytes/s, done.
> Total 35 (delta 30), reused 0 (delta 0)
> remote: error: insufficient permission for adding an object to repository
> database objects
> remote: fatal: failed to write object
> error: unpack failed: unpack-objects abnormal exit
> To git at bitbucket.org:petsc/petsc
> ! [remote rejected] knepley/feature-harmonic-advection ->
> knepley/feature-harmonic-advection (unpacker error)
> error: failed to push some refs to 'git at bitbucket.org:petsc/petsc'
> Matt
