[petsc-dev] implementation header incluing ../src
Jed Brown
jed at jedbrown.org
Thu Feb 19 16:05:04 CST 2015
Matthew Knepley <knepley at gmail.com> writes:
>> > It does not look like anything else uses hash.h. Can we just move it to
>> > include/petschash.h?
>> Why does it need to be included by a header?
> I thought something else was using this, but it looks like I am the
> only one. We should put it in a header and clear out the cruft no one
> uses anymore:
I was asking why you include it from dmpleximpl.h. Can you remove that
and just include it from the necessary source files? I'm fine with
petsc-private/hashimpl.h, and of course remove the cruft.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150219/9a9b0c3c/attachment.sig>
