[petsc-dev] GAMG broken in master
    Tobin Isaac
    tisaac at ices.utexas.edu
    Wed Feb 18 22:57:00 CST 2015
On Wed, Feb 18, 2015 at 10:06:18PM -0600, Barry Smith wrote:
>   Hmm, it seems GAMG is only doing 2 levels in master for all problems?
> ./ex29 -da_refine 8 -pc_type gamg -ksp_view
> uses only two levels. Makes no sense.
>  Did someone break it?
Here's the culprit:
https://bitbucket.org/petsc/petsc/commits/25a145a7bcab6e5b3c8766679c77bee80f328690#Lsrc/ksp/pc/impls/gamg/gamg.cT664
It now always stops when there is only one active process.
  Toby
> > On Feb 18, 2015, at 9:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >  Mark,
> >   When I run ksp/ksp/examples/tutorials/ex45 I get a VERY large coarse problem. It seems to ignore the -pc_gamg_coarse_eq_limit 200 argument. Any idea what is going on?
> >   Thanks
> >    Barry
> > $ ./ex45 -da_refine 3 -pc_type gamg -ksp_monitor -ksp_view -log_summary -pc_gamg_coarse_eq_limit 200
> >  0 KSP Residual norm 2.790769524030e+02
> >  1 KSP Residual norm 4.484052193577e+01
> >  2 KSP Residual norm 2.409368790441e+00
> >  3 KSP Residual norm 1.553421589919e-01
> >  4 KSP Residual norm 9.821441923699e-03
> >  5 KSP Residual norm 5.610434857134e-04
> > KSP Object: 1 MPI processes
> >  type: gmres
> >    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
> >    GMRES: happy breakdown tolerance 1e-30
> >  maximum iterations=10000
> >  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
> >  left preconditioning
> >  using nonzero initial guess
> >  using PRECONDITIONED norm type for convergence test
> > PC Object: 1 MPI processes
> >  type: gamg
> >    MG: type is MULTIPLICATIVE, levels=2 cycles=v
> >      Cycles per PCApply=1
> >      Using Galerkin computed coarse grid matrices
> >  Coarse grid solver -- level -------------------------------
> >    KSP Object:    (mg_coarse_)     1 MPI processes
> >      type: gmres
> >      maximum iterations=1, initial guess is zero
> >      using NONE norm type for convergence test
> >    PC Object:    (mg_coarse_)     1 MPI processes
> >      type: bjacobi
> >        block Jacobi: number of blocks = 1
> >        Local solve is same for all blocks, in the following KSP and PC objects:
> >        KSP Object:        (mg_coarse_sub_)         1 MPI processes
> >          type: preonly
> >        PC Object:        (mg_coarse_sub_)         1 MPI processes
> >          type: lu
> >            LU: out-of-place factorization
> >            tolerance for zero pivot 2.22045e-14
> >            using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
> >            matrix ordering: nd
> >            factor fill ratio given 5, needed 36.4391
> >              Factored matrix follows:
> >                Mat Object:                 1 MPI processes
> >                  type: seqaij
> >                  rows=16587, cols=16587
> >                  package used to perform factorization: petsc
> >                  total: nonzeros=1.8231e+07, allocated nonzeros=1.8231e+07
> >                  total number of mallocs used during MatSetValues calls =0
> >                    not using I-node routines
> >          linear system matrix = precond matrix:
> >            type: seqaij
> >            total: nonzeros=500315, allocated nonzeros=500315
> >        type: seqaij
> >  Down solver (pre-smoother) on level 1 -------------------------------
> >    KSP Object:    (mg_levels_1_)     1 MPI processes
> >      type: chebyshev
> >        Chebyshev: eigenvalue estimates:  min = 0.0976343, max = 2.05032
> >      maximum iterations=2
> >    PC Object:    (mg_levels_1_)     1 MPI processes
> >      type: sor
> >        SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
> >        type: seqaij
> >        rows=117649, cols=117649
> >        total: nonzeros=809137, allocated nonzeros=809137
> >  Up solver (post-smoother) same as down solver (pre-smoother)
> >    type: seqaij
> > Residual norm 3.81135e-05
> > ***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
> > ---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
> > ./ex45 on a arch-opt named Barrys-MacBook-Pro.local with 1 processor, by barrysmith Wed Feb 18 21:38:03 2015
> > Using Petsc Development GIT revision: v3.5.3-1998-geddef31  GIT Date: 2015-02-18 11:05:09 -0600
> >                         Max       Max/Min        Avg      Total
> > Time (sec):           1.103e+01      1.00000   1.103e+01
> > Objects:              9.200e+01      1.00000   9.200e+01
> > Flops:                1.756e+10      1.00000   1.756e+10  1.756e+10
> > Flops/sec:            1.592e+09      1.00000   1.592e+09  1.592e+09
> > MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
> > MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
> > MPI Reductions:       0.000e+00      0.00000
> > Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
> >                            e.g., VecAXPY() for real vectors of length N --> 2N flops
> >                            and VecAXPY() for complex vectors of length N --> 8N flops
> > Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
> >                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
> > 0:      Main Stage: 1.1030e+01 100.0%  1.7556e+10 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
> > See the 'Profiling' chapter of the users' manual for details on interpreting output.
> > Phase summary info:
> >   Count: number of times phase was executed
> >   Time and Flops: Max - maximum over all processors
> >                   Ratio - ratio of maximum to minimum over all processors
> >   Mess: number of messages sent
> >   Avg. len: average message length (bytes)
> >   Reduct: number of global reductions
> >   Global: entire computation
> >   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
> >      %T - percent time in this phase         %F - percent flops in this phase
> >      %M - percent messages in this phase     %L - percent message lengths in this phase
> >      %R - percent reductions in this phase
> >   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
> > Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
> >                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> > --- Event Stage 0: Main Stage
> > KSPGMRESOrthog        21 1.0 8.8868e-03 1.0 3.33e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3752
> > KSPSetUp               5 1.0 4.3986e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > KSPSolve               1 1.0 1.0995e+01 1.0 1.76e+10 1.0 0.0e+00 0.0e+00 0.0e+00100100  0  0  0 100100  0  0  0  1596
> > VecMDot               21 1.0 4.7335e-03 1.0 1.67e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3522
> > VecNorm               30 1.0 9.4804e-04 1.0 4.63e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4887
> > VecScale              29 1.0 7.8293e-04 1.0 2.20e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2809
> > VecCopy               14 1.0 7.7058e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > VecSet               102 1.0 1.4530e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > VecAXPY                9 1.0 3.8154e-04 1.0 9.05e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2372
> > VecAYPX               48 1.0 5.6449e-03 1.0 7.06e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1251
> > VecAXPBYCZ            24 1.0 4.0700e-03 1.0 1.41e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3469
> > VecMAXPY              29 1.0 5.1512e-03 1.0 2.04e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3960
> > VecAssemblyBegin       1 1.0 6.7055e-08 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > VecAssemblyEnd         1 1.0 8.1025e-08 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > VecPointwiseMult      11 1.0 1.8083e-03 1.0 1.29e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   716
> > VecSetRandom           1 1.0 1.7628e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > VecNormalize          29 1.0 1.7100e-03 1.0 6.60e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3858
> > MatMult               58 1.0 5.0949e-02 1.0 8.39e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1647
> > MatMultAdd             6 1.0 5.2584e-03 1.0 5.01e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   952
> > MatMultTranspose       6 1.0 6.1330e-03 1.0 5.01e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   816
> > MatSolve              12 1.0 2.0657e-01 1.0 4.37e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2  2  0  0  0   2  2  0  0  0  2117
> > MatSOR                36 1.0 7.1355e-02 1.0 5.84e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   818
> > MatLUFactorSym         1 1.0 3.4310e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
> > MatLUFactorNum         1 1.0 9.8038e+00 1.0 1.69e+10 1.0 0.0e+00 0.0e+00 0.0e+00 89 96  0  0  0  89 96  0  0  0  1721
> > MatConvert             1 1.0 5.6955e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > MatScale               3 1.0 2.7223e-03 1.0 2.45e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   901
> > MatResidual            6 1.0 6.2142e-03 1.0 9.71e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1562
> > MatAssemblyBegin      12 1.0 2.7413e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > MatAssemblyEnd        12 1.0 2.4857e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > MatGetRow         470596 1.0 2.4337e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > MatGetRowIJ            1 1.0 2.3254e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > MatGetOrdering         1 1.0 1.7668e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > MatCoarsen             1 1.0 8.5790e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > MatView                5 1.0 2.2273e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > MatAXPY                1 1.0 1.8864e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > MatMatMult             1 1.0 2.4513e-02 1.0 2.03e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    83
> > MatMatMultSym          1 1.0 1.7885e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > MatMatMultNum          1 1.0 6.6144e-03 1.0 2.03e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   307
> > MatPtAP                1 1.0 1.1460e-01 1.0 1.30e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   114
> > MatPtAPSymbolic        1 1.0 4.6803e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > MatPtAPNumeric         1 1.0 6.7781e-02 1.0 1.30e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   192
> > MatTrnMatMult          1 1.0 9.1702e-02 1.0 1.02e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   111
> > MatTrnMatMultSym       1 1.0 6.0173e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> > MatTrnMatMultNum       1 1.0 3.1526e-02 1.0 1.02e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   324
> > MatGetSymTrans         2 1.0 4.2753e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > PCGAMGgraph_AGG        1 1.0 6.9175e-02 1.0 1.62e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0    23
> > PCGAMGcoarse_AGG       1 1.0 1.1130e-01 1.0 1.02e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0    92
> > PCGAMGProl_AGG         1 1.0 2.9380e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > PCGAMGPOpt_AGG         1 1.0 9.1377e-02 1.0 5.15e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   564
> > PCSetUp                2 1.0 1.0587e+01 1.0 1.69e+10 1.0 0.0e+00 0.0e+00 0.0e+00 96 97  0  0  0  96 97  0  0  0  1601
> > PCSetUpOnBlocks        6 1.0 1.0165e+01 1.0 1.69e+10 1.0 0.0e+00 0.0e+00 0.0e+00 92 96  0  0  0  92 96  0  0  0  1660
> > PCApply                6 1.0 1.0503e+01 1.0 1.75e+10 1.0 0.0e+00 0.0e+00 0.0e+00 95 99  0  0  0  95 99  0  0  0  1662
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150218/91d49af6/attachment.sig>
