[petsc-dev] Incident INC0062690 updated -- error building metis on Edison
Mark Adams
mfadams at lbl.gov
Wed Feb 18 10:02:32 CST 2015
Well, this error seems to have come back on Edison. I am using camke 2.8.11.2
(see log attached).
On Mon, Feb 9, 2015 at 6:34 PM, NERSC Consulting and Support <
nersc at service-now.com> wrote:
> Short description: error building metis on Edison
> Click here to view incident: INC0062690
> <https://nersc.service-now.com/nav_to.do?uri=incident.do%3Fsys_id=e4242b2a6f06710016fb68826e3ee4c6%26sysparm_stack=incident_list.do%3Fsysparm_query=active=true>
> metis_config_error.txt
> <https://nersc.service-now.com/sys_attachment.do?sys_id=f204afe66fc671002a9e58622e3ee4e0>
> Comments:
> 2015-02-09 15:34:15 - Scott French (Additional comments)
> Hi Mark,
> Thanks for the update. Good luck, and let me know if you run into trouble
> with cmake/2.8.11.2 (I'm still a bit puzzled as to why this version does
> not insist on adding -rdynamic to the link line).
> Cheers,
> Scott French
> NERSC User Services
> 2015-02-09 13:26:16 - Mark Adams (Additional comments)
> reply from: mfadams at lbl.gov
> OK, thanks. I was trying static to try to fix that :)
> PETSc's configure scripts, which I prefer to use do not allow 3.0.0 (we
> will fix that).
> I will try 2.8.11.2
> Thanks again,
> Mark
> On Mon, Feb 9, 2015 at 4:19 PM,
> Ref:MSG0591148
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150218/fc893e94/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150218/fc893e94/attachment.obj>
