[petsc-dev] GNU Global / gtags users: please try updated 'make allgtags'
Tobin Isaac tisaac at ices.utexas.edu
Wed Feb 18 08:42:11 CST 2015
'make allgtags' has some non-portable (OS X?) syntax: brace expansion
in the shell and the -E flag for 'find'.  I tried making the rule
portable, in tisaac/fix-makefile-allgtags.  Merging into next wouldn't
actually test the change, so: if you use gtags, could you please let
me know if it breaks in your environment?
  Toby
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150218/1cadcc6c/attachment.sig>
