[petsc-dev] Branches in next but not merged to master
Matthew Knepley
knepley at gmail.com
Wed Feb 11 07:28:11 CST 2015
On Tue, Feb 10, 2015 at 8:11 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Perhaps some of these need to be moved to master or perhaps just deleted
> in the repository?
> $ gitmasternotupdated
> 2014-10-13 11:59:12 -0600
> (origin/dmeiser/pullrequest-fix-PetscOptionsEnum) Use current value for
> default in PetscOptionsEnum().
> 2014-10-20 10:48:20 -0500 (origin/knepley/fix-vec-f90) Vec: Remove
> continuation by using shorter variable name
Merged
> 2014-12-25 12:55:29 -0600 (origin/tisaac/simplify-register-all) You moved
> PETSC_EXTERN MatRegisterAll() to matimpl.h but did not change the mat
> 2015-01-22 19:33:55 -0700 (origin/jed/ksp-explicit-operator-BAorAB)
> KSPComputeExplicitOperator: use KSP_PCApplyBAorAB
> 2015-01-29 13:56:32 -0600 (origin/tisaac/fix-gamg-square-graph) GAMG:
> keep track of coarsening level
> 2015-02-06 12:53:29 -0600 (origin/knepley/fix-plex-orient-1d) Plex: Fix
> orientation in 1D - Forgot to include flipping check in 1D code
> 2015-02-06 12:58:06 -0600 (origin/knepley/feature-partitioner-simple)
> Plex: Removed unused variable
> 2015-02-06 15:47:42 -0600 (origin/knepley/fix-vec-readonly) Plex: Added
> read-only Vec fixes for point location and interpolation
2015-02-10 07:13:23 -0600 (origin/knepley/fix-veclock-fftw) DM: Fix more
> Vec lock issues
These 4 are merged.
Matt
> 2015-02-10 14:30:52 +0300 (origin/pr257/petsc/dalcinl/fix-draw/maint,
> pr257/petsc/dalcinl/fix-draw/maint) PetscDrawLGDraw: draw and flush only
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150211/5f4eb9bd/attachment.html>
