[petsc-dev] Branches in next but not merged to master
Tue Feb 10 20:11:39 CST 2015
  Perhaps some of these need to be moved to master or perhaps just deleted in the repository?
$ gitmasternotupdated
2014-10-13 11:59:12 -0600  (origin/dmeiser/pullrequest-fix-PetscOptionsEnum) Use current value for default in PetscOptionsEnum().
2014-10-20 10:48:20 -0500  (origin/knepley/fix-vec-f90) Vec: Remove continuation by using shorter variable name
2014-12-25 12:55:29 -0600  (origin/tisaac/simplify-register-all) You moved PETSC_EXTERN MatRegisterAll() to matimpl.h but did not change the mat
2015-01-22 19:33:55 -0700  (origin/jed/ksp-explicit-operator-BAorAB) KSPComputeExplicitOperator: use KSP_PCApplyBAorAB
2015-01-29 13:56:32 -0600  (origin/tisaac/fix-gamg-square-graph) GAMG: keep track of coarsening level
2015-02-06 12:53:29 -0600  (origin/knepley/fix-plex-orient-1d) Plex: Fix orientation in 1D - Forgot to include flipping check in 1D code
2015-02-06 12:58:06 -0600  (origin/knepley/feature-partitioner-simple) Plex: Removed unused variable
2015-02-06 15:47:42 -0600  (origin/knepley/fix-vec-readonly) Plex: Added read-only Vec fixes for point location and interpolation
2015-02-10 07:13:23 -0600  (origin/knepley/fix-veclock-fftw) DM: Fix more Vec lock issues
2015-02-10 14:30:52 +0300  (origin/pr257/petsc/dalcinl/fix-draw/maint, pr257/petsc/dalcinl/fix-draw/maint) PetscDrawLGDraw: draw and flush only
