[petsc-dev] TSSolve web page  JED and EMIL READ THIS!
    Jed Brown
    jed at jedbrown.org
    Fri Feb  6 21:35:16 CST 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
>    I am not proposing removing the solution from TSSolve() argument
>    list, far from it. I am proposing removing the TSSetSolution(),
>    keeping the solution in TSSolve() as the standard approach, but
>    also allowing a callback for when the user wants the DM passed to
>    TS to be in charge of creating all the vectors.
Oh, that's fine if/when you have a use case for it.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150206/27969ef7/attachment.sig>
