[petsc-dev] [Bitbucket] Issue #116: Included version of HYPRE has outdated config.sub, guess (petsc/petsc)
Satish Balay
balay at mcs.anl.gov
Thu Dec 17 16:30:46 CST 2015
I created hypre-2.10.0b-p3.tar.gz and updated maint (merged to
master,next) to use this tarball..
Satish
On Thu, 17 Dec 2015, Barry Smith wrote:
> Satish,
> Looks like you should patch the latest two downloaded hypre tarballs with this fix.
> Thanks
> Barry
> > On Dec 16, 2015, at 1:47 AM, daxtens <issues-reply at bitbucket.org> wrote:
> > daxtens created issue #116:
> > Included version of HYPRE has outdated config.sub,guess
> > When running configure according to the MOOSE setup instructions (http://mooseframework.com/wiki/BasicManualInstallation/Linux/#2-petsc), I get the following error on powerpc 64-bit, little-endian:
> > checking build system type... config/config.guess: unable to guess system type
> > This script, last modified 2005-08-03, has failed to recognize
> > the operating system you are using. It is advised that you
> > download the most up to date version of the config scripts from
> > http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.guess
> > and
> > http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.sub
> > If the version you run (config/config.guess) is already up to date, please
> > send the following data and any information you think might be
> > pertinent to <config-patches at gnu.org> in order to provide the needed
> > information to handle your system.
> > config.guess timestamp = 2005-08-03
> > uname -m = ppc64le
> > uname -r = 4.2.0-19-generic
> > uname -s = Linux
> > uname -v = #23-Ubuntu SMP Wed Nov 11 11:38:17 UTC 2015
> > /usr/bin/uname -p =
> > /bin/uname -X =
> > hostinfo =
> > /bin/universe =
> > /usr/bin/arch -k =
> > /bin/arch =
> > /usr/bin/oslevel =
> > /usr/convex/getsysinfo =
> > UNAME_MACHINE = ppc64le
> > UNAME_RELEASE = 4.2.0-19-generic
> > UNAME_SYSTEM = Linux
> > UNAME_VERSION = #23-Ubuntu SMP Wed Nov 11 11:38:17 UTC 2015
> > configure: error: cannot guess build type; you must specify one
> > I have emailed the HYPRE devs to get this fixed upstream., but until then, this is easy to fix with the following two commands, run after it has been extracted:
> > find . -name config.sub -exec wget -O \{\} 'http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD' \;
> > find . -name config.guess -exec wget -O
> > \{\} 'http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD' \;
> > (Yes, these commands are slightly overkill - it would be possible to refine them a bit.)
> > After that it configures, builds and runs fine.
> > Would it be possible to automatically download the newer versions please?
> > Type:
> > bug
> > Priority:
> > major
> > View this issue or add a comment by replying to this email.
> > Unsubscribe from issue emails for this repository.
