[petsc-dev] bullshit in Plex example under complex
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Aug 28 14:02:49 CDT 2015
   This test should never be run in complex. if it is not coded for it. Please update the makefile rule for running it only without complex
> Null vector 2 is likely null vector|| A * v[2] || = 9.22162e-17
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: I don't think this makes sense for complex numbers
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.6.1-977-ga9ee8f1  GIT Date: 2015-08-27 23:56:46 -0500
> [0]PETSC ERROR: ./ex3 on a arch-opensolaris-cmplx-pkgs-dbg named n-gage by petsc Fri Aug 28 10:53:50 2015
> [0]PETSC ERROR: Configure options --with-debugger=/bin/true --with-scalar-type=complex --with-mpi-dir=/export/home/petsc/soft/mpich2-1.2.1p1 --with-c2html=0 --download-cmake=1 --download-metis=1 --download-parmetis=1 --download-triangle=1 --download-fblaslapack=1 --download-scalapack=1 --download-mumps=1 --with-no-output -PETSC_ARCH=arch-opensolaris-cmplx-pkgs-dbg -PETSC_DIR=/export/home/petsc/petsc.clone-3
> [0]PETSC ERROR: #1 PetscFVLeastSquaresPseudoInverseSVD_Static() line 2112 in /export/home/petsc/petsc.clone-3/src/dm/dt/interface/dtfv.c
> [0]PETSC ERROR: #2 PetscFVComputeGradient_LeastSquares() line 2197 in /export/home/petsc/petsc.clone-3/src/dm/dt/interface/dtfv.c
> [0]PETSC ERROR: #3 PetscFVComputeGradient() line 1729 in /export/home/petsc/petsc.clone-3/src/dm/dt/interface/dtfv.c
> [0]PETSC ERROR: #4 BuildGradientReconstruction_Internal_Tree() line 1790 in /export/home/petsc/petsc.clone-3/src/dm/impls/plex/plexgeometry.c
> [0]PETSC ERROR: #5 DMPlexComputeGradientFVM() line 1845 in /export/home/petsc/petsc.clone-3/src/dm/impls/plex/plexgeometry.c
> [0]PETSC ERROR: #6 DMPlexSNESGetGradientDM() line 927 in /export/home/petsc/petsc.clone-3/src/snes/utils/dmplexsnes.c
> [0]PETSC ERROR: #7 TestFVGrad() line 523 in /export/home/petsc/petsc.clone-3/src/dm/impls/plex/examples/tests/ex3.c
> [0]PETSC ERROR: #8 main() line 889 in /export/home/petsc/petsc.clone-3/src/dm/impls/plex/examples/tests/ex3.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -dim 2
> [0]PETSC ERROR: -display 140.221.10.20:0.0
> [0]PETSC ERROR: -dm_plex_max_projection_height 1
> [0]PETSC ERROR: -dm_view ascii::ASCII_INFO_DETAIL
> [0]PETSC ERROR: -fv_grad
> [0]PETSC ERROR: -malloc_dump
> [0]PETSC ERROR: -mat_null_space_test_view
> [0]PETSC ERROR: -num_comp 2
> [0]PETSC ERROR: -petsclimiter_type none
> [0]PETSC ERROR: -petscpartitioner_type simple
> [0]PETSC ERROR: -petscspace_order 1
> [0]PETSC ERROR: -petscspace_poly_tensor
> [0]PETSC ERROR: -qorder 1
> [0]PETSC ERROR: -simplex 0
> [0]PETSC ERROR: -tree
> [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
> [1]PETSC ERROR: --------------------- Error Message -------------------------------------------------------
