[petsc-dev] [GPU - slepc] Hands-on exercise 4 (SVD) not working with GPU and default configurations
    Leoni, Massimiliano
    Massimiliano.Leoni at Rolls-Royce.com
    Mon Aug 10 08:55:18 CDT 2015
> -----Original Message-----
> From: Karl Rupp [mailto:rupp at iue.tuwien.ac.at]
> Sent: 10 August 2015 14:13
> To: Leoni, Massimiliano
> Cc: slepc-maint at upv.es; petsc-dev at mcs.anl.gov
> Subject: Re: [petsc-dev] [GPU - slepc] Hands-on exercise 4 (SVD) not working
> Maybe you forgot to call SlepcFinalize()?
Unfortunately it's not it, if I omit SlepcFinalize() an error message shows up at runtime to remind me.
> Ok, this is actually a relatively GPU-friendly setup, because CPUs have
> reduced the gap in terms of FLOPs quite a bit (see for example
> http://www.karlrupp.net/2013/06/cpu-gpu-and-mic-hardware-
> characteristics-over-time/  )
Read, thanks for sharing!
> I'd suggest to convince your supervisor into buying/using a cluster with
> current hardware and enjoy a higher speedup compared to what you could
> get in an ideal setting with a GPU from 2010 anyway ;-)
This could partly be overcome as I was told I *might*, eventually, have access to a big cluster with many NVIDIA Tesla K20.
> (Having said that, I carefully estimate that you can get some
> performance gains for SVD if you deep-dive into the existing SVD
> implementation, carefully redesign it to minimize CPU<->GPU
> communication, and use optimized library routines from the BLAS 3
> operations. Currently there is not enough GPU-infrastructure in PETSc to
> achieve this via command line parameters only.)
Mmm, can you give a rough estimate of the effort involved in this?
>From: Matthew Knepley [mailto:knepley at gmail.com]
>Sent: 10 August 2015 14:28
>Cc: Karl Rupp; slepc-maint at upv.es; petsc-dev at mcs.anl.gov
>Subject: Re: [petsc-dev] [GPU - slepc] Hands-on exercise 4 (SVD) not working with GPU and default configurations
>Try calling PetscLogBegin() after PetscInitialize(). We have now put in an error if this is not initialized correctly.
This didn’t do the trick, unfortunately
Do I have to pull from the repo and rebuild?
[In general, can I pull and rebuild without running configure again?]
>I agree with Karl that not much speedup can be expected with GPUs. This is the fault of dishonest marketing. None
>of the computations in PETSc are limited by the computation rate, rather they are limited by memory bandwidth. The
>bandwidth is at best 2-3x better, and less for modern CPUs. The dense SVD can be better than this, but you are
>eventually limited by offload times and memory latency. The story of 100x, or even 10x, speedups is just a fraud.
I remember reading this in one of the petsc reports [the “Preliminary evaluation” one?].
I’ll see what I can do
Best regards,
Massimiliano
The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 1332 622800(Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
(c) 2015 Rolls-Royce plc
Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150810/c01c2f1a/attachment.html>
