[petsc-dev] [GPU - slepc] Hands-on exercise 4 (SVD) not working with GPU and default configurations
Leoni, Massimiliano
Massimiliano.Leoni at Rolls-Royce.com
Fri Aug 7 09:31:33 CDT 2015
Hi everybody!
I kept experimenting with slepc and GPUs, and when I turned to SVD I found out that the hands-on exercise on SVD [#4] doesn't run properly.
If I run it on CPU it works fine, whereas...
$ mpirun -np 1 slepcSVD -file $SLEPC_DIR/share/slepc/datafiles/matrices/rdb200.petsc -bv_type vecs -mat_type aijcusp -on_error_abort
Singular value problem stored in file.
Reading REAL matrix from a binary file...
[0]PETSC ERROR: BVScaleColumn() line 380 in /gpfs/rrcfd/rruk-students/apps/slepc/src/sys/classes/bv/interface/bvops.c Scalar value must be same on all processes, argument # 3
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] PetscAbortErrorHandler line 56 /gpfs/rrcfd/rruk-students/apps/petsc/src/sys/error/errabort.c
[0]PETSC ERROR: [0] PetscError line 363 /gpfs/rrcfd/rruk-students/apps/petsc/src/sys/error/err.c
[0]PETSC ERROR: [0] BVScaleColumn line 377 /gpfs/rrcfd/rruk-students/apps/slepc/src/sys/classes/bv/interface/bvops.c
[0]PETSC ERROR: [0] EPSFullLanczos line 357 /gpfs/rrcfd/rruk-students/apps/slepc/src/eps/impls/krylov/epskrylov.c
[0]PETSC ERROR: [0] EPSSolve_KrylovSchur_Symm line 41 /gpfs/rrcfd/rruk-students/apps/slepc/src/eps/impls/krylov/krylovschur/ks-symm.c
[0]PETSC ERROR: [0] EPSSolve line 83 /gpfs/rrcfd/rruk-students/apps/slepc/src/eps/interface/epssolve.c
[0]PETSC ERROR: [0] SVDSolve_Cross line 155 /gpfs/rrcfd/rruk-students/apps/slepc/src/svd/impls/cross/cross.c
[0]PETSC ERROR: [0] SVDSolve line 92 /gpfs/rrcfd/rruk-students/apps/slepc/src/svd/interface/svdsolve.c
[0]PETSC ERROR: User provided function() line 0 in unknown file (null)
mpirun noticed that process rank 0 with PID 11264 on node gpu3 exited on signal 11 (Segmentation fault).
I am using the same command line options that work just fine on hands-on exercises 1 and 2, which feature EPS solvers.
Any hint appreciated.
Best regards,
Massimiliano Leoni
The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 1332 622800(Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
(c) 2015 Rolls-Royce plc
Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150807/ea3b7a82/attachment.html>
