[petsc-dev] EM solver in XGC
Tue Apr 14 17:33:59 CDT 2015
On Tue, Apr 14, 2015 at 5:19 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Matt, in looking at MatConvert_Nest_AIJ, the code looks like it is 2 years
> old.
> I need a MatConvert_Nest_MPIAIJ, should I write this or does it exist
> someplace?
This is MPIAIJ. Look at the code.
  Matt
> Mark
> On Tue, Apr 14, 2015 at 2:54 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> Also, this is with MPI so I need MPIAIJ.  Is that supposed to work?
>> On Tue, Apr 14, 2015 at 2:53 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> It looks like MatConvert is looking for "MatConvert_nest_aij_C"
>>> but I see:
>>> > git grep MatConvert_Nest
>>> impls/nest/matnest.c:#define __FUNCT__ "MatConvert_Nest_AIJ"
>>> impls/nest/matnest.c:PETSC_EXTERN PetscErrorCode MatConvert_Nest_AIJ(Mat
>>> A,MatType newtype,MatReuse reuse,Mat *newmat)
>>> Is there a problems with "Nest" vs "nest" here?
>>> Mark
>>> On Tue, Apr 14, 2015 at 2:46 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> I have tried
>>>>  call
>>>> MatConvert(a_ts%FJacobian,MATMPIAIJ,MAT_INITIAL_MATRIX,a_ts%FJacobian2,ierr);CHKERRQ(ierr)
>>>> and
>>>>  call
>>>> MatConvert(a_ts%FJacobian,MATAIJ,MAT_INITIAL_MATRIX,a_ts%FJacobian2,ierr);CHKERRQ(ierr)
>>>> in 'next' and it is not finding the specialized routine.
>>>> I will look into it.
>>>> Mark
>>>> On Tue, Apr 14, 2015 at 1:41 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Tue, Apr 14, 2015 at 12:40 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Tue, Apr 14, 2015 at 12:33 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> MatNest does not support convert because it does not have a getrow.
>>>>>> I think this got fixed in dev. Anyhow, this supports my contention
>>>>>> that MatNest is a piece of shit.
>>>>> Use 'next', it has
>>>>>    PETSC_EXTERN PetscErrorCode MatConvert_Nest_AIJ(Mat A,MatType
>>>>> so it should work.
>>>>>    Matt
>>>>>>> Should we use a 4 block fieldsplit?
>>>>>> We give up our ability to check using exact solves, but go ahead and
>>>>>> try it if you think it will make
>>>>>> the physicists happy for now.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> On Tue, Apr 14, 2015 at 1:26 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> OK,
>>>>>>>> On Tue, Apr 14, 2015 at 1:25 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Tue, Apr 14, 2015 at 12:23 PM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>> wrote:
>>>>>>>>>> I moved this to after the setup, which it has to do because it
>>>>>>>>>> does not have the prefix or set options.
>>>>>>>>>> It is not failing with not finding the IS.  Will MatNest be able
>>>>>>>>>> to merge two matrices together like this?
>>>>>>>>>> I create a 4x4 MatNext but have just two fields in fieldSplit.
>>>>>>>>> Yep, I believe that will work. If not, just convert the MatNest to
>>>>>>>>> an AIJ for now with MatConvert().
>>>>>>>>>    Matt
>>>>>>>>>> On Tue, Apr 14, 2015 at 1:18 PM, Matthew Knepley <
>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>> On Tue, Apr 14, 2015 at 12:13 PM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> I get an error where it looks like the number fields in field
>>>>>>>>>>>> split is < 2.  Do I need to set the size?
>>>>>>>>>>> No, each call to SetIS() just appends to the field list.
>>>>>>>>>>>> I use this code but I do this before I have setup the TS.
>>>>>>>>>>>> Should I do this after I setup the TS?
>>>>>>>>>>> This is why I hate using the API since it is difficult to get
>>>>>>>>>>> all the setup done at the right time. First,
>>>>>>>>>>> when you call PCFieldSplitSetIS(), is the PC type set?
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>      Matt
>>>>>>>>>>>>   ! setup field split
>>>>>>>>>>>>   call TSGetSNES(a_ts,snes,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>   call SNESGetKSP(snes,ksp,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>   call KSPGetPC(ksp,pc,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>   call
>>>>>>>>>>>> MatGetSize(a_ts%mass,PETSC_NULL_INTEGER,npetsc,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>   npetsc = 2*npetsc ! two blocks in each partition
>>>>>>>>>>>>   j = 0
>>>>>>>>>>>>   call
>>>>>>>>>>>> ISCreateStride(w_comm,npetsc,j,ione,is,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>   call PCFieldSplitSetIS(pc,'dt',is,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>   call ISDestroy(is,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>   j = npetsc
>>>>>>>>>>>>   call
>>>>>>>>>>>>   call PCFieldSplitSetIS(pc,'aux',is,ierr);CHKERRQ(ierr)
>>>>>>>>>>>> On Tue, Apr 14, 2015 at 12:24 PM, Matthew Knepley <
>>>>>>>>>>>>> On Tue, Apr 14, 2015 at 11:16 AM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> Should I just use
>>>>>>>>>>>>>> PetscErrorCode  VecGetSubVector(Vec X,IS is,Vec *Y)
>>>>>>>>>>>>> Yep, that is exactly what I use it for.
>>>>>>>>>>>>>   Matt
>>>>>>>>>>>>>> On Tue, Apr 14, 2015 at 12:15 PM, Mark Adams <mfadams at lbl.gov
>>>>>>>>>>>>>> > wrote:
>>>>>>>>>>>>>>> I am thinking that I should create an IS that is my local
>>>>>>>>>>>>>>> part of each field and then get a "sub vector" with that somehow.  Looking
>>>>>>>>>>>>>>> into this now.
>>>>>>>>>>>>>>> On Tue, Apr 14, 2015 at 12:00 PM, Mark Adams <
>>>>>>>>>>>>>>>> Whoop, old code still there.
>>>>>>>>>>>>>>>> I now have to get access to vectors somehow.
>>>>>>>>>>>>>>>> I now get vectors for a field and do stuff with them like:
>>>>>>>>>>>>>>>> subroutine
>>>>>>>>>>>>>>>> FormIFunction(ts,t_dummy,a_XX,a_Xdot,a_FF,a_ts,ierr)
>>>>>>>>>>>>>>>>   call TSGetDM(ts,dm,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>>   call
>>>>>>>>>>>>>>>> DMCompositeGetAccessArray(dm,a_FF,ifour,PETSC_NULL_INTEGER,Fsub,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>>   call
>>>>>>>>>>>>>>>> DMCompositeGetAccessArray(dm,a_Xdot,ifour,PETSC_NULL_INTEGER,Xdotsub,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>>   one = 1d0
>>>>>>>>>>>>>>>>   call VecAXPY(Fsub(1),one,Xdotsub(1),ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>>   call VecAXPY(Fsub(2),one,Xdotsub(2),ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>>   call
>>>>>>>>>>>>>>>> DMCompositeRestoreAccessArray(dm,a_Xdot,ifour,PETSC_NULL_INTEGER,Xdotsub,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>>   call
>>>>>>>>>>>>>>>> DMCompositeRestoreAccessArray(dm,a_FF,ifour,PETSC_NULL_INTEGER,Fsub,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>>   call
>>>>>>>>>>>>>>>> MatMultAdd(a_ts%FJacobian,a_XX,a_FF,a_FF,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>> I need to get rid of DMCompositeGetAccessArray.  What do I
>>>>>>>>>>>>>>>> do?
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Mark
>>>>>>>>>>>>>>>> On Tue, Apr 14, 2015 at 11:36 AM, Matthew Knepley <
>>>>>>>>>>>>>>>>> On Tue, Apr 14, 2015 at 10:35 AM, Mark Adams <
>>>>>>>>>>>>>>>>>> And is this the solver (appended).
>>>>>>>>>>>>>>>>> Do not call SNESSetDM(). We are not using DM at all in
>>>>>>>>>>>>>>>>> this code.
>>>>>>>>>>>>>>>>>   Matt
>>>>>>>>>>>>>>>>>> I am getting an error at this last line:
>>>>>>>>>>>>>>>>>> .seealso: SNESGetDM(), KSPSetDM(), KSPGetDM()
>>>>>>>>>>>>>>>>>> PetscErrorCode  SNESSetDM(SNES snes,DM dm)
>>>>>>>>>>>>>>>>>>   PetscErrorCode ierr;
>>>>>>>>>>>>>>>>>>   KSP            ksp;
>>>>>>>>>>>>>>>>>>   DMSNES         sdm;
>>>>>>>>>>>>>>>>>>   PetscFunctionBegin;
>>>>>>>>>>>>>>>>>>   PetscValidHeaderSpecific(snes,SNES_CLASSID,1);
>>>>>>>>>>>>>>>>>>   if (dm) {ierr =
>>>>>>>>>>>>>>>>>> PetscObjectReference((PetscObject)dm);CHKERRQ(ierr);}
>>>>>>>>>>>>>>>>>>   if (snes->dm) {               /* Move the DMSNES
>>>>>>>>>>>>>>>>>> context over to the new DM unless the new DM already has one */
>>>>>>>>>>>>>>>>>>     if (snes->dm->dmsnes && snes->dmAuto && !dm->dmsnes) {
>>>>>>>>>>>>>>>>>> The problem is that the argument 'dm' to this method is
>>>>>>>>>>>>>>>>>> NULL so I get a segv at the last term of this conditional.
>>>>>>>>>>>>>>>>>> Mark
>>>>>>>>>>>>>>>>>> -adv_ts_type beuler
>>>>>>>>>>>>>>>>>> -adv_ts_monitor
>>>>>>>>>>>>>>>>>> -adv_ts_view
>>>>>>>>>>>>>>>>>> -adv_ts_max_step 1
>>>>>>>>>>>>>>>>>> -adv_snes_max_it 1                    # make >> 1 for
>>>>>>>>>>>>>>>>>> nonlinear solve
>>>>>>>>>>>>>>>>>> -adv_snes_lag_preconditioner -1       # make > 0 to
>>>>>>>>>>>>>>>>>> update PC
>>>>>>>>>>>>>>>>>> -adv_snes_lag_jacobian -1             # make > 0 for
>>>>>>>>>>>>>>>>>> nonlinear Jacobian
>>>>>>>>>>>>>>>>>> -adv_snes_monitor
>>>>>>>>>>>>>>>>>> -adv_snes_converged_reason
>>>>>>>>>>>>>>>>>> -adv_ksp_monitor
>>>>>>>>>>>>>>>>>> -adv_ksp_converged_reason
>>>>>>>>>>>>>>>>>> -adv_ksp_type richardson
>>>>>>>>>>>>>>>>>> -adv_pc_type fieldsplit
>>>>>>>>>>>>>>>>>> #-adv_pc_fieldsplit_type multiplicative
>>>>>>>>>>>>>>>>>> -adv_pc_fieldsplit_type schur
>>>>>>>>>>>>>>>>>> -adv_pc_fieldsplit_schur_fact_type full
>>>>>>>>>>>>>>>>>> -adv_pc_fieldsplit_schur_precondition full
>>>>>>>>>>>>>>>>>> #-adv_pc_fieldsplit_0_fields 0,1
>>>>>>>>>>>>>>>>>> #-adv_pc_fieldsplit_1_fields 2,3
>>>>>>>>>>>>>>>>>> -adv_fieldsplit_dt_pc_type lu
>>>>>>>>>>>>>>>>>> -adv_fieldsplit_aux_pc_type lu
>>>>>>>>>>>>>>>>>> -adv_fieldsplit_dt_pc_factor_mat_solver_package superlu
>>>>>>>>>>>>>>>>>> -adv_fieldsplit_aux_pc_factor_mat_solver_package superlu
>>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150414/b979cbe6/attachment.html>
