[petsc-dev] EM solver in XGC
    Mark Adams
    mfadams at lbl.gov
    Tue Apr 14 17:19:07 CDT 2015
Matt, in looking at MatConvert_Nest_AIJ, the code looks like it is 2 years
old.
I need a MatConvert_Nest_MPIAIJ, should I write this or does it exist
someplace?
On Tue, Apr 14, 2015 at 2:54 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Also, this is with MPI so I need MPIAIJ.  Is that supposed to work?
> On Tue, Apr 14, 2015 at 2:53 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> It looks like MatConvert is looking for "MatConvert_nest_aij_C"
>> but I see:
>> > git grep MatConvert_Nest
>> impls/nest/matnest.c:#define __FUNCT__ "MatConvert_Nest_AIJ"
>> impls/nest/matnest.c:PETSC_EXTERN PetscErrorCode MatConvert_Nest_AIJ(Mat
>> A,MatType newtype,MatReuse reuse,Mat *newmat)
>> Is there a problems with "Nest" vs "nest" here?
>> Mark
>> On Tue, Apr 14, 2015 at 2:46 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> I have tried
>>>  call
>>> MatConvert(a_ts%FJacobian,MATMPIAIJ,MAT_INITIAL_MATRIX,a_ts%FJacobian2,ierr);CHKERRQ(ierr)
>>> and
>>>  call
>>> MatConvert(a_ts%FJacobian,MATAIJ,MAT_INITIAL_MATRIX,a_ts%FJacobian2,ierr);CHKERRQ(ierr)
>>> in 'next' and it is not finding the specialized routine.
>>> I will look into it.
>>> Mark
>>> On Tue, Apr 14, 2015 at 1:41 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Tue, Apr 14, 2015 at 12:40 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Tue, Apr 14, 2015 at 12:33 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> MatNest does not support convert because it does not have a getrow.
>>>>> I think this got fixed in dev. Anyhow, this supports my contention
>>>>> that MatNest is a piece of shit.
>>>> Use 'next', it has
>>>>    PETSC_EXTERN PetscErrorCode MatConvert_Nest_AIJ(Mat A,MatType
>>>> so it should work.
>>>>    Matt
>>>>>> Should we use a 4 block fieldsplit?
>>>>> We give up our ability to check using exact solves, but go ahead and
>>>>> try it if you think it will make
>>>>> the physicists happy for now.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> On Tue, Apr 14, 2015 at 1:26 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> OK,
>>>>>>> On Tue, Apr 14, 2015 at 1:25 PM, Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Tue, Apr 14, 2015 at 12:23 PM, Mark Adams <mfadams at lbl.gov>
>>>>>>>> wrote:
>>>>>>>>> I moved this to after the setup, which it has to do because it
>>>>>>>>> does not have the prefix or set options.
>>>>>>>>> It is not failing with not finding the IS.  Will MatNest be able
>>>>>>>>> to merge two matrices together like this?
>>>>>>>>> I create a 4x4 MatNext but have just two fields in fieldSplit.
>>>>>>>> Yep, I believe that will work. If not, just convert the MatNest to
>>>>>>>> an AIJ for now with MatConvert().
>>>>>>>>    Matt
>>>>>>>>> On Tue, Apr 14, 2015 at 1:18 PM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Tue, Apr 14, 2015 at 12:13 PM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>> wrote:
>>>>>>>>>>> I get an error where it looks like the number fields in field
>>>>>>>>>>> split is < 2.  Do I need to set the size?
>>>>>>>>>> No, each call to SetIS() just appends to the field list.
>>>>>>>>>>> I use this code but I do this before I have setup the TS.
>>>>>>>>>>> Should I do this after I setup the TS?
>>>>>>>>>> This is why I hate using the API since it is difficult to get all
>>>>>>>>>> the setup done at the right time. First,
>>>>>>>>>> when you call PCFieldSplitSetIS(), is the PC type set?
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>>   ! setup field split
>>>>>>>>>>>   call TSGetSNES(a_ts,snes,ierr);CHKERRQ(ierr)
>>>>>>>>>>>   call SNESGetKSP(snes,ksp,ierr);CHKERRQ(ierr)
>>>>>>>>>>>   call KSPGetPC(ksp,pc,ierr);CHKERRQ(ierr)
>>>>>>>>>>>   call
>>>>>>>>>>> MatGetSize(a_ts%mass,PETSC_NULL_INTEGER,npetsc,ierr);CHKERRQ(ierr)
>>>>>>>>>>>   npetsc = 2*npetsc ! two blocks in each partition
>>>>>>>>>>>   j = 0
>>>>>>>>>>>   call ISCreateStride(w_comm,npetsc,j,ione,is,ierr);CHKERRQ(ierr)
>>>>>>>>>>>   call PCFieldSplitSetIS(pc,'dt',is,ierr);CHKERRQ(ierr)
>>>>>>>>>>>   call ISDestroy(is,ierr);CHKERRQ(ierr)
>>>>>>>>>>>   j = npetsc
>>>>>>>>>>>   call PCFieldSplitSetIS(pc,'aux',is,ierr);CHKERRQ(ierr)
>>>>>>>>>>> On Tue, Apr 14, 2015 at 12:24 PM, Matthew Knepley <
>>>>>>>>>>>> On Tue, Apr 14, 2015 at 11:16 AM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> Should I just use
>>>>>>>>>>>>> PetscErrorCode  VecGetSubVector(Vec X,IS is,Vec *Y)
>>>>>>>>>>>> Yep, that is exactly what I use it for.
>>>>>>>>>>>>   Matt
>>>>>>>>>>>>> On Tue, Apr 14, 2015 at 12:15 PM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> I am thinking that I should create an IS that is my local
>>>>>>>>>>>>>> part of each field and then get a "sub vector" with that somehow.  Looking
>>>>>>>>>>>>>> into this now.
>>>>>>>>>>>>>> On Tue, Apr 14, 2015 at 12:00 PM, Mark Adams <mfadams at lbl.gov
>>>>>>>>>>>>>> > wrote:
>>>>>>>>>>>>>>> Whoop, old code still there.
>>>>>>>>>>>>>>> I now have to get access to vectors somehow.
>>>>>>>>>>>>>>> I now get vectors for a field and do stuff with them like:
>>>>>>>>>>>>>>> subroutine
>>>>>>>>>>>>>>> FormIFunction(ts,t_dummy,a_XX,a_Xdot,a_FF,a_ts,ierr)
>>>>>>>>>>>>>>>   call TSGetDM(ts,dm,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>   call
>>>>>>>>>>>>>>> DMCompositeGetAccessArray(dm,a_FF,ifour,PETSC_NULL_INTEGER,Fsub,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>   call
>>>>>>>>>>>>>>> DMCompositeGetAccessArray(dm,a_Xdot,ifour,PETSC_NULL_INTEGER,Xdotsub,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>   one = 1d0
>>>>>>>>>>>>>>>   call VecAXPY(Fsub(1),one,Xdotsub(1),ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>   call VecAXPY(Fsub(2),one,Xdotsub(2),ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>   call
>>>>>>>>>>>>>>> DMCompositeRestoreAccessArray(dm,a_Xdot,ifour,PETSC_NULL_INTEGER,Xdotsub,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>   call
>>>>>>>>>>>>>>> DMCompositeRestoreAccessArray(dm,a_FF,ifour,PETSC_NULL_INTEGER,Fsub,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>>   call
>>>>>>>>>>>>>>> MatMultAdd(a_ts%FJacobian,a_XX,a_FF,a_FF,ierr);CHKERRQ(ierr)
>>>>>>>>>>>>>>> I need to get rid of DMCompositeGetAccessArray.  What do I
>>>>>>>>>>>>>>> do?
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Mark
>>>>>>>>>>>>>>> On Tue, Apr 14, 2015 at 11:36 AM, Matthew Knepley <
>>>>>>>>>>>>>>>> On Tue, Apr 14, 2015 at 10:35 AM, Mark Adams <
>>>>>>>>>>>>>>>>> And is this the solver (appended).
>>>>>>>>>>>>>>>> Do not call SNESSetDM(). We are not using DM at all in this
>>>>>>>>>>>>>>>> code.
>>>>>>>>>>>>>>>>   Matt
>>>>>>>>>>>>>>>>> I am getting an error at this last line:
>>>>>>>>>>>>>>>>> .seealso: SNESGetDM(), KSPSetDM(), KSPGetDM()
>>>>>>>>>>>>>>>>> PetscErrorCode  SNESSetDM(SNES snes,DM dm)
>>>>>>>>>>>>>>>>>   PetscErrorCode ierr;
>>>>>>>>>>>>>>>>>   KSP            ksp;
>>>>>>>>>>>>>>>>>   DMSNES         sdm;
>>>>>>>>>>>>>>>>>   PetscFunctionBegin;
>>>>>>>>>>>>>>>>>   PetscValidHeaderSpecific(snes,SNES_CLASSID,1);
>>>>>>>>>>>>>>>>>   if (dm) {ierr =
>>>>>>>>>>>>>>>>> PetscObjectReference((PetscObject)dm);CHKERRQ(ierr);}
>>>>>>>>>>>>>>>>>   if (snes->dm) {               /* Move the DMSNES context
>>>>>>>>>>>>>>>>> over to the new DM unless the new DM already has one */
>>>>>>>>>>>>>>>>>     if (snes->dm->dmsnes && snes->dmAuto && !dm->dmsnes) {
>>>>>>>>>>>>>>>>> The problem is that the argument 'dm' to this method is
>>>>>>>>>>>>>>>>> NULL so I get a segv at the last term of this conditional.
>>>>>>>>>>>>>>>>> Mark
>>>>>>>>>>>>>>>>> -adv_ts_type beuler
>>>>>>>>>>>>>>>>> -adv_ts_monitor
>>>>>>>>>>>>>>>>> -adv_ts_view
>>>>>>>>>>>>>>>>> -adv_ts_max_step 1
>>>>>>>>>>>>>>>>> -adv_snes_max_it 1                    # make >> 1 for
>>>>>>>>>>>>>>>>> nonlinear solve
>>>>>>>>>>>>>>>>> -adv_snes_lag_preconditioner -1       # make > 0 to update
>>>>>>>>>>>>>>>>> PC
>>>>>>>>>>>>>>>>> -adv_snes_lag_jacobian -1             # make > 0 for
>>>>>>>>>>>>>>>>> nonlinear Jacobian
>>>>>>>>>>>>>>>>> -adv_snes_monitor
>>>>>>>>>>>>>>>>> -adv_snes_converged_reason
>>>>>>>>>>>>>>>>> -adv_ksp_monitor
>>>>>>>>>>>>>>>>> -adv_ksp_converged_reason
>>>>>>>>>>>>>>>>> -adv_ksp_type richardson
>>>>>>>>>>>>>>>>> -adv_pc_type fieldsplit
>>>>>>>>>>>>>>>>> #-adv_pc_fieldsplit_type multiplicative
>>>>>>>>>>>>>>>>> -adv_pc_fieldsplit_type schur
>>>>>>>>>>>>>>>>> -adv_pc_fieldsplit_schur_fact_type full
>>>>>>>>>>>>>>>>> -adv_pc_fieldsplit_schur_precondition full
>>>>>>>>>>>>>>>>> #-adv_pc_fieldsplit_0_fields 0,1
>>>>>>>>>>>>>>>>> #-adv_pc_fieldsplit_1_fields 2,3
>>>>>>>>>>>>>>>>> -adv_fieldsplit_dt_pc_type lu
>>>>>>>>>>>>>>>>> -adv_fieldsplit_aux_pc_type lu
>>>>>>>>>>>>>>>>> -adv_fieldsplit_dt_pc_factor_mat_solver_package superlu
>>>>>>>>>>>>>>>>> -adv_fieldsplit_aux_pc_factor_mat_solver_package superlu
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150414/5d3d149f/attachment.html>
