[petsc-dev] Clang Analyzer
Lisandro Dalcin
dalcinl at gmail.com
Mon Apr 13 03:33:15 CDT 2015
Jed, hold on. I think this will not work. Does GCC or other compilers
that do support __attribute__((something)) have support for
__has_attribute(something) ?
For now, I'll only add the bits required for getting clang analyzer happy.
On 13 April 2015 at 10:50, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 13 April 2015 at 03:13, Jed Brown <jed at jedbrown.org> wrote:
>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>> Lisandro,
>>> More code analysis is always good. We'll figure something out for this particular beast. Note that petscsys.h already uses #if defined(__has_attribute) so maybe we can use
>>> # if __has_attribute(analyzer_noreturn)
>>> instead of the #ifdef __clang_analyzer__?
>> Should we add a PETSC_HAS_ATTRIBUTE(analyzer_noreturn) to make this less
>> verbose? (It would return 0 if __has_attribute is not available.) I
>> foresee more use of __has_attribute to reduce the number of tests we
>> have to run and make petscconf.h more robust to, e.g., minor version
>> changes in the compiler stack.
> Yes, of course, this is much better. I guess petscsys.h is the right
> place to add this logic. I'll put this together in a PR.
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Numerical Porous Media Center (NumPor)
> King Abdullah University of Science and Technology (KAUST)
> http://numpor.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 4332
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
Lisandro Dalcin
Research Scientist
