[petsc-dev] Clang Analyzer
Lisandro Dalcin
dalcinl at gmail.com
Mon Apr 13 02:50:38 CDT 2015
On 13 April 2015 at 03:13, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>> Lisandro,
>> More code analysis is always good. We'll figure something out for this particular beast. Note that petscsys.h already uses #if defined(__has_attribute) so maybe we can use
>> # if __has_attribute(analyzer_noreturn)
>> instead of the #ifdef __clang_analyzer__?
> Should we add a PETSC_HAS_ATTRIBUTE(analyzer_noreturn) to make this less
> verbose? (It would return 0 if __has_attribute is not available.) I
> foresee more use of __has_attribute to reduce the number of tests we
> have to run and make petscconf.h more robust to, e.g., minor version
> changes in the compiler stack.
Yes, of course, this is much better. I guess petscsys.h is the right
place to add this logic. I'll put this together in a PR.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Numerical Porous Media Center (NumPor)
King Abdullah University of Science and Technology (KAUST)
http://numpor.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 4332
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
