[petsc-dev] PETSc blame digest (next) 2015-04-08
Barry Smith
bsmith at mcs.anl.gov
Wed Apr 8 10:58:41 CDT 2015
Jed,
These warnings have traditionally been filtered out; the new edition of checkBuilds did not filter them (from Solaris compilers) I asked Toby and Satish to filter them but they ignored me so I can add the filter later today. It is not intended that we change the code to remove the warnings.
Barry
> On Apr 8, 2015, at 9:08 AM, Jed Brown <jed at jedbrown.org> wrote:
> PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> writes:
>> warnings attributed to commit ac76247 Point-to-point PetscSF: bcast and reduce, still need fetch-and-op, ref #9
>> src/vec/is/sf/impls/basic/sfbasic.c:816
>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/08/build_next_arch-opensolaris-cmplx-pkgs-dbg_n-gage.log]
>> "/export/home/petsc/petsc.clone-3/src/vec/is/sf/impls/basic/sfbasic.c", line 816: warning: loop not entered at top
> How do we fix this? If I remove the final (unreached)
> PetscFunctionReturn(0) then the code is invalid when not
> PETSC_USE_ERRORCHECKING (no return statement in function returning
> non-void). But as long as error checking is on, we don't reach that
> statement. Can we tune the warning flags to avoid this noise?
> static PetscErrorCode PetscSFBasicGetPackInUse(PetscSF sf,MPI_Datatype unit,const void *key,PetscCopyMode cmode,PetscSFBasicPack *mylink)
> PetscSF_Basic *bas = (PetscSF_Basic*)sf->data;
> PetscErrorCode ierr;
> PetscSFBasicPack link,*p;
> PetscFunctionBegin;
> /* Look for types in cache */
> for (p=&bas->inuse; (link=*p); p=&link->next) {
> PetscBool match;
> ierr = MPIPetsc_Type_compare(unit,link->unit,&match);CHKERRQ(ierr);
> if (match && (key == link->key)) {
> switch (cmode) {
> case PETSC_OWN_POINTER: *p = link->next; break; /* Remove from inuse list */
> case PETSC_USE_POINTER: break;
> default: SETERRQ(PETSC_COMM_SELF,PETSC_ERR_ARG_INCOMP,"invalid cmode");
> *mylink = link;
> PetscFunctionReturn(0);
> SETERRQ(PetscObjectComm((PetscObject)sf),PETSC_ERR_ARG_WRONGSTATE,"Could not find pack");
