[petsc-dev] 'master' RESET after bad merge! - 'tisaac/thplex' was based on 'next'
Tue Sep 2 11:06:16 CDT 2014
On Tue, Sep 2, 2014 at 10:07 AM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
> On Tue, Sep 02, 2014 at 09:04:46AM -0500, Matthew Knepley wrote:
> > On Tue, Sep 2, 2014 at 9:02 AM, Tobin Isaac <tisaac at ices.utexas.edu>
> wrote:
> > > On Tue, Sep 02, 2014 at 07:57:29AM -0600, Jed Brown wrote:
> > > > Tobin Isaac <tisaac at ices.utexas.edu> writes:
> > > > >> Matt and Toby: 'tisaac/thplex' needs to be rebased onto 'master'
> > > before
> > > > >> we can accept it.  Matt, please remember to look at what you are
> > > > >> merging.  When the commit message says you are merging hundreds of
> > > > >> commits, but you didn't review hundreds of commits, it should be a
> > > sign
> > > > >> that something is amiss.
> > > > > Matt, do you want me to handle this?
> > > > I'm perusing history with
> > > >   gitk master..tisaac/thplex     # includes recent merge of
> > > 'tisaac/dm-dim-embed-auto' with recent stuff from 'next'
> > > >   gitk master..tisaac/thplex^^   # much cleaner, but still based on
> > > 'next'
> > > > I would probably fix by creating a new branch and cherry-picking the
> > > > ranges of clean commits starting from the oldest commits in your
> branch.
> > > Aleady have gitk open and tisaac/thplex-on-master created.  I have to
> > > be little careful about GetDimension() being moved from DMPlex to DM,
> > > but I think I've got it.
> > Okay, cool. I will let you do the merge. Let me know and I will test
> stuff
> > after its done.
> Okay, tisaac/thplex-on-master is based on master and passed `make
> testexamples`.  It brings in knepley/fix-quadrature-order, too.  I'll
> defer on merging into master in case you want to run more tests.
My tests are clean. You can merge to master after the nightly builds are
clean.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140902/ba6bc59b/attachment.html>
