[petsc-dev] 'master' RESET after bad merge! - 'tisaac/thplex' was based on 'next'
    Tobin Isaac
    tisaac at ices.utexas.edu
    Tue Sep  2 10:07:16 CDT 2014
On Tue, Sep 02, 2014 at 09:04:46AM -0500, Matthew Knepley wrote:
> On Tue, Sep 2, 2014 at 9:02 AM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
> > On Tue, Sep 02, 2014 at 07:57:29AM -0600, Jed Brown wrote:
> > > Tobin Isaac <tisaac at ices.utexas.edu> writes:
> > > >> Matt and Toby: 'tisaac/thplex' needs to be rebased onto 'master'
> > before
> > > >> we can accept it.  Matt, please remember to look at what you are
> > > >> merging.  When the commit message says you are merging hundreds of
> > > >> commits, but you didn't review hundreds of commits, it should be a
> > sign
> > > >> that something is amiss.
> > > > Matt, do you want me to handle this?
> > > I'm perusing history with
> > >   gitk master..tisaac/thplex     # includes recent merge of
> > 'tisaac/dm-dim-embed-auto' with recent stuff from 'next'
> > >   gitk master..tisaac/thplex^^   # much cleaner, but still based on
> > 'next'
> > > I would probably fix by creating a new branch and cherry-picking the
> > > ranges of clean commits starting from the oldest commits in your branch.
> > Aleady have gitk open and tisaac/thplex-on-master created.  I have to
> > be little careful about GetDimension() being moved from DMPlex to DM,
> > but I think I've got it.
> Okay, cool. I will let you do the merge. Let me know and I will test stuff
> after its done.
Okay, tisaac/thplex-on-master is based on master and passed `make
testexamples`.  It brings in knepley/fix-quadrature-order, too.  I'll
defer on merging into master in case you want to run more tests.
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140902/afdd3d1a/attachment.sig>
