[petsc-dev] How to compose a git URL for going through 2 machines
Satish Balay
balay at mcs.anl.gov
Wed Nov 5 13:50:06 CST 2014
just concentrate on setting up ssh tunnel. git shouldn't have to deal
with it. Look for 'ssh ProxyCommand' [google]
Perhaps the following will work for you.
Add the following to ~/.ssh/config
Host lu-fe1.lanl.gov
ProxyCommand ssh -q -a -x wdn at red-wtrw.lanl.gov /bin/nc %h %p
Now you check if ssh works:
ssh lu-fe1.lanl.gov ls /usr/projects/artab/users/wdn/repos/git/petsc
And then use:
git clone lu-fe1.lanl.gov:/usr/projects/artab/users/wdn/repos/git/petsc
Satish
On Wed, 5 Nov 2014, Nystrom, William David wrote:
> I was wondering if anyone might know the solution to a problem I am having with
> composing a git URL for cloning a git repo that is two machines away.
> I'm trying to execute the following git command:
> git clone ssh://wdn@red-wtrw.lanl.gov/lu-fe1.lanl.gov/usr/projects/artab/users/wdn/repos/git/petsc
> I've also tried the following:
> git clone ssh://wdn@red-wtrw.lanl.gov:lu-fe1.lanl.gov/usr/projects/artab/users/wdn/repos/git/petsc
> And also
> git clone ssh://wdn@red-wtrw.lanl.gov:lu-fe1.lanl.gov:/usr/projects/artab/users/wdn/repos/git/petsc
> Basically, I have to go through a gateway machine running a restricted shell
> to get to a machine which mounts the filesystem where my git repo is located.
> Each of the above commands fail.
> However, I can run the following scp command successfully:
> scp -p file_name wdn at red-wtrw.lanl.gov:lu-fe1.lanl.gov:/usr/projects/artab/users/wdn
> So I'm wondering if there is a way to chain together two machines in a git URL like I can
> with scp or whether there is some fundamental reason why this just will not work. Does
> anyone know if what I am doing is possible and if so, how? Or do I have to set up and
> use an ssh tunnel?
> Thanks,
> Dave
> Dave Nystrom
> LANL HPC-5
> Phone: 505-667-7913
> Email: wdn at lanl.gov
> Smail: Mail Stop B272
> Group HPC-5
> Los Alamos National Laboratory
> Los Alamos, NM 87545
