[petsc-dev] How to compose a git URL for going through 2 machines
Aron Ahmadia aron at ahmadia.net
Wed Nov 5 13:48:35 CST 2014
You want an SSH tunnel uses local port forwarding.    The instructions here
are pretty clear:
https://help.ubuntu.com/community/SSH/OpenSSH/PortForwarding
On Wed, Nov 5, 2014 at 2:42 PM, Nystrom, William David <wdn at lanl.gov> wrote:
> I was wondering if anyone might know the solution to a problem I am having
> with
> composing a git URL for cloning a git repo that is two machines away.
> I'm trying to execute the following git command:
> git clone ssh://
> wdn at red-wtrw.lanl.gov/lu-fe1.lanl.gov/usr/projects/artab/users/wdn/repos/git/petsc
> I've also tried the following:
> git clone ssh://wdn@red-wtrw.lanl.gov:l
> And also
> git clone ssh://wdn@red-wtrw.lanl.gov:lu-fe1.lanl.gov:
> Basically, I have to go through a gateway machine running a restricted
> shell
> to get to a machine which mounts the filesystem where my git repo is
> located.
> Each of the above commands fail.
> However, I can run the following scp command successfully:
> scp -p file_name wdn at red-wtrw.lanl.gov:lu-fe1.lanl.gov:
> So I'm wondering if there is a way to chain together two machines in a git
> URL like I can
> with scp or whether there is some fundamental reason why this just will
> not work.  Does
> anyone know if what I am doing is possible and if so, how?  Or do I have
> to set up and
> use an ssh tunnel?
> Thanks,
> Dave
> Dave Nystrom
> LANL HPC-5
> Phone: 505-667-7913
> Email: wdn at lanl.gov
> Smail: Mail Stop B272
>        Group HPC-5
>        Los Alamos National Laboratory
>        Los Alamos, NM 87545
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141105/9b3ecdc6/attachment.html>
