[petsc-dev] remove KSPSPECEST ?
Jed Brown
jed at jedbrown.org
Tue Mar 11 23:08:05 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
> NOTHING is ever zero maintenance! I stubble across it while working
> on HTML formatted output and had to decide do I work my way through
> it or not, I did not. These left over zero maintenance things are
> always a pain when doing global changes to stuff.
In the last three years, I don't see any changes that wouldn't have been
done with a script. I guess this HTML stuff is different.
> What functionality does it have that is not elsewhere, what cool
> structure is there but no where else? Can that be transported over
> to where it would actually get used and not become a bit cavity?
Just the auto-estimates that can be used with methods other than
Chebyshev. If you want to remove it, just do that and I'll copy the
Chebyshev estimating code when I need it in a polynomial smoother for
nonsymmetric problems.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140311/a0c904f3/attachment.sig>
