[petsc-dev] problem building on Mira
    Mark Adams
    mfadams at lbl.gov
    Sat Jun 28 10:00:40 CDT 2014
And this is the configure log.
On Sat, Jun 28, 2014 at 4:48 PM, Mark Adams <mfadams at lbl.gov> wrote:
> PETSc,
> I am trying to build a code with PETSc on Mira and I seem to be getting
> some conflicting declarations.
> I have pulled from dev and reconfigured PETSc today.  Any ideas?
> Mark
> mpixlcxx_r -g       -DCH_SPACEDIM=3 -DCH_Linux    -DCH_MPI
> -DMPICH_SKIP_MPICXX -ULAM_WANT_MPI2CPP -DMPI_NO_CPPBIND    -DCH_USE_SETVAL
> -DCH_USE_COMPLEX   -DCH_USE_MEMORY_TRACKING  -DCH_USE_64 -DCH_USE_DOUBLE
> -DCH_USE_HDF5 -I/soft/libraries/hdf5/1.8.10/cnk-xl/current/include
> -DH5_USE_16_API      -DCH_USE_PETSC -I/home/adams/petsc_public/include
> -I/home/adams/petsc_public/arch-bgq-ibm-opt-64idx/include
> -I/gpfs/mira-home/adams/petsc_public/arch-bgq-ibm-opt-64idx/include
> -I/bgsys/drivers/V1R2M1/ppc64/comm/include
> -I/bgsys/drivers/V1R2M1/ppc64/comm/lib/xl -I/bgsys/drivers/V1R2M1/ppc64
> -I/bgsys/drivers/V1R2M1/ppc64/comm/sys/include
> -I/bgsys/drivers/V1R2M1/ppc64/spi/include
> -I/bgsys/drivers/V1R2M1/ppc64/spi/include/kernel/cnk  -DCH_FORT_UNDERSCORE
> -I/gpfs/mira-home/adams/Chombo/lib/src/AMRElliptic/../../src/AMRTools
> -I/gpfs/mira-home/adams/Chombo/lib/src/AMRElliptic/../../src/BoxTools
> -I/gpfs/mira-home/adams/Chombo/lib/src/AMRElliptic/../../src/BaseTools
>  -DCH_LANG_CC -c PetscCompGrid.cpp -o
> o/3d.Linux.64.mpixlcxx_r.mpixlf77_r.DEBUG.MPI.PETSC/PetscCompGrid.o
> "/gpfs/mira-home/adams/Chombo/lib/src/AMRElliptic/../../src/BoxTools/ProblemDomain.H",
> line 447.14: 1540-1091 (W) The friend declaration "bdryLo" specifies a
> default argument expression and is not a definition.
> line 460.14: 1540-1091 (W) The friend declaration "bdryHi" specifies a
> line 490.14: 1540-1091 (W) The friend declaration "adjCellLo" specifies a
> line 521.14: 1540-1091 (W) The friend declaration "adjCellHi" specifies a
> "/home/adams/petsc_public/arch-bgq-ibm-opt-64idx/include/petscfix.h", line
> 7.5: 1540-0400 (S) "getdomainname(char *, size_t)" has a conflicting
> declaration.
> "/bgsys/drivers/toolchain/V1R2M1_base/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/unistd.h",
> line 916.12: 1540-0424 (I) "getdomainname" is declared on line 916 of
> "/bgsys/drivers/toolchain/V1R2M1_base/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/unistd.h".
> 8.8: 1540-0400 (S) "drand48()" has a conflicting declaration.
> "/bgsys/drivers/toolchain/V1R2M1_base/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h",
> line 395.15: 1540-0424 (I) "drand48" is declared on line 395 of
> "/bgsys/drivers/toolchain/V1R2M1_base/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h".
> 9.8: 1540-0400 (S) "srand48(long)" has a conflicting declaration.
> line 409.13: 1540-0424 (I) "srand48" is declared on line 409 of
> "/gpfs/mira-home/adams/Chombo/lib/src/AMRElliptic/../../src/BoxTools/IntVectSet.H",
> line 387.3: 1540-1091 (W) The friend declaration "refine" specifies a
> line 409.3: 1540-1091 (W) The friend declaration "coarsen" specifies a
> gmake[2]: ***
> [o/3d.Linux.64.mpixlcxx_r.mpixlf77_r.DEBUG.MPI.PETSC/PetscCompGrid.o] Error
> 1
> gmake[1]: *** [AMRElliptic] Error 2
> make: *** [AMRElliptic] Error 2
> [adams at miralac1 execBCG]$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140628/2490decf/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140628/2490decf/attachment.obj>
