[petsc-dev] problem building on Mira
Mark Adams
mfadams at lbl.gov
Sat Jun 28 09:48:03 CDT 2014
PETSc,
I am trying to build a code with PETSc on Mira and I seem to be getting
some conflicting declarations.
I have pulled from dev and reconfigured PETSc today. Any ideas?
mpixlcxx_r -g -DCH_SPACEDIM=3 -DCH_Linux -DCH_MPI
-DMPICH_SKIP_MPICXX -ULAM_WANT_MPI2CPP -DMPI_NO_CPPBIND -DCH_USE_SETVAL
-DCH_USE_COMPLEX -DCH_USE_MEMORY_TRACKING -DCH_USE_64 -DCH_USE_DOUBLE
-DCH_USE_HDF5 -I/soft/libraries/hdf5/1.8.10/cnk-xl/current/include
-DH5_USE_16_API -DCH_USE_PETSC -I/home/adams/petsc_public/include
-I/home/adams/petsc_public/arch-bgq-ibm-opt-64idx/include
-I/gpfs/mira-home/adams/petsc_public/arch-bgq-ibm-opt-64idx/include
-I/bgsys/drivers/V1R2M1/ppc64/comm/include
-I/bgsys/drivers/V1R2M1/ppc64/comm/lib/xl -I/bgsys/drivers/V1R2M1/ppc64
-I/bgsys/drivers/V1R2M1/ppc64/comm/sys/include
-I/bgsys/drivers/V1R2M1/ppc64/spi/include
-I/bgsys/drivers/V1R2M1/ppc64/spi/include/kernel/cnk -DCH_FORT_UNDERSCORE
-I/gpfs/mira-home/adams/Chombo/lib/src/AMRElliptic/../../src/AMRTools
-I/gpfs/mira-home/adams/Chombo/lib/src/AMRElliptic/../../src/BoxTools
-I/gpfs/mira-home/adams/Chombo/lib/src/AMRElliptic/../../src/BaseTools
-DCH_LANG_CC -c PetscCompGrid.cpp -o
o/3d.Linux.64.mpixlcxx_r.mpixlf77_r.DEBUG.MPI.PETSC/PetscCompGrid.o
"/gpfs/mira-home/adams/Chombo/lib/src/AMRElliptic/../../src/BoxTools/ProblemDomain.H",
line 447.14: 1540-1091 (W) The friend declaration "bdryLo" specifies a
default argument expression and is not a definition.
line 460.14: 1540-1091 (W) The friend declaration "bdryHi" specifies a
line 490.14: 1540-1091 (W) The friend declaration "adjCellLo" specifies a
line 521.14: 1540-1091 (W) The friend declaration "adjCellHi" specifies a
"/home/adams/petsc_public/arch-bgq-ibm-opt-64idx/include/petscfix.h", line
7.5: 1540-0400 (S) "getdomainname(char *, size_t)" has a conflicting
declaration.
"/bgsys/drivers/toolchain/V1R2M1_base/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/unistd.h",
line 916.12: 1540-0424 (I) "getdomainname" is declared on line 916 of
"/bgsys/drivers/toolchain/V1R2M1_base/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/unistd.h".
8.8: 1540-0400 (S) "drand48()" has a conflicting declaration.
"/bgsys/drivers/toolchain/V1R2M1_base/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h",
line 395.15: 1540-0424 (I) "drand48" is declared on line 395 of
"/bgsys/drivers/toolchain/V1R2M1_base/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h".
9.8: 1540-0400 (S) "srand48(long)" has a conflicting declaration.
line 409.13: 1540-0424 (I) "srand48" is declared on line 409 of
"/gpfs/mira-home/adams/Chombo/lib/src/AMRElliptic/../../src/BoxTools/IntVectSet.H",
line 387.3: 1540-1091 (W) The friend declaration "refine" specifies a
line 409.3: 1540-1091 (W) The friend declaration "coarsen" specifies a
gmake[2]: ***
[o/3d.Linux.64.mpixlcxx_r.mpixlf77_r.DEBUG.MPI.PETSC/PetscCompGrid.o] Error
1
gmake[1]: *** [AMRElliptic] Error 2
make: *** [AMRElliptic] Error 2
[adams at miralac1 execBCG]$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140628/89db8e7f/attachment.html>
