[petsc-dev] Updating MOAB version during download
Jed Brown
jed at jedbrown.org
Tue Jun 17 01:10:26 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>>>> Are you going to add the appropriate upstream workflow to all the
>>>> --download packages? This sounds intractable.
>>> I am not putting upstream workflow into any download packages. I am
>>> wanting to do something very simple, let —download-xxx replace me
>>> manually git clone xxxx; git checkout yyyy on some package. That is
>>> all. (Where yyy may be a branch or a commit-hash depending on the
>>> circumstances).
>> It clones and checks out the commit. You can checkout the BRANCH
>> (branches are all about how the upstream package CHANGES) when you want
>> to contribute upstream (and you're entirely on your own to match up with
>> their workflow). Why is that not sufficient?
> Since —download-xxx can already track a branch
I don't want that because tracking a branch is a broken model. It is
just not enforced because "git checkout branchname" works just as well
as "git checkout commit-hash".
> the only thing that is missing is managing merges from these
> branches into next and master so that things don’t break and don’t
> require people to remember “oh since I am tracking a moab branch I
> have to be really careful when I merge into next/master and
> manually fix things”.
Forget the merge problem, this is already a broken model at square one.
There is no reproducibility or reviewability.
> Ideally it would automatically switch from branch to commit-hash on
> such merges in xxx.py
It should always use a commit. The branch can change and be deleted
later. The commit is permanent so long as it has been accepted.
> If that is not possible then it would print a useful message to the
> screen telling one to manually fix the xxx.py commit-hash to the
> appropriate value when I do the merge.
> Since you and Satish just go on and on about how this is a bad idea
> instead of just telling me how to make git do this I have to assume
> that git cannot do it and you guys are just trying to find
> rationalizations of why I would not want to do this rather than
> just admitting git cannot do it. So
I don't care what the tool can do because it's a broken model. A commit
hook can check for compatibility, but it's not supposed to modify the
tree (and I think that doing so would be a sin due to ambiguous
specification).
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140617/e1641142/attachment.sig>
