[petsc-dev] License change to 2-clause BSD
    Jed Brown
    jed at jedbrown.org
    Mon Jun 16 11:07:08 CDT 2014
We have received approval to adopt a 2-clause BSD license (aka
"Simplified BSD" or "FreeBSD") for the upcoming release of PETSc.  This
license is essentially compatible with the existing PETSc license, but
we believe this change is desirable to reduce license proliferation [1]
and to make it easy to check license compatibility.  The 2-clause BSD
license (along with the essentially-equivalent MIT/X11 license) is the
most permissive license in common use, so this should not affect
anyone's ability to use PETSc.
If you object to this change, or if you have contributed code to PETSc
and would like to specially label your contribution as retaining the
(compatible) legacy PETSc license, please reply here or write
petsc-maint at mcs.anl.gov.
[1] https://en.wikipedia.org/wiki/License_proliferation
Copyright (c) 1991-2014, UChicago Argonne, LLC and the PETSc Development Team
All rights reserved.
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright notice, this
  list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright notice, this
  list of conditions and the following disclaimer in the documentation and/or
  other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
This license DOES NOT apply to any software that may be obtained via the
--download-package option of the PETSc configuration. Each of those
packages are covered by their own licenses.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140616/5bb84c7a/attachment.sig>
