[petsc-dev] PETSc release last chance for code changes
    Jason Sarich
    jason.sarich at gmail.com
    Sun Jun 15 14:19:58 CDT 2014
Satish,
sarich/fix-tao-valgrind-warning
This is the branch you helped me merge a month or two ago, it can be
removed now.
sarich/tao-purge-dm
I thought I pushed this to master yesterday, it's possible it didn't go
right. I am away from my computer today, can you merge this for me,
otherwise I'll get it late tonight.
Jason
 On Jun 15, 2014 10:28 AM, "Balay, Satish" <balay at mcs.anl.gov> wrote:
> On Thu, 12 Jun 2014, Barry Smith wrote:
> >    Please get all changes into master before 9pm central time USA on
> Sunday June 15th that you would like in the release. At that time Satish
> will make a release branch and the only changes allowed in that release
> branch will be bug fixes that do not change the API.
> Perhaps some of these branches [which are already merged to next] should
> be merged to master?
> [and if they are false positives - perhaps those branches should be
> deleted?]
> thanks,
> Satish
> $ candidate-branches next master
> Candidate for master: refs/remotes/origin/irving/doc-cleanup Fri Jan 31
> 23:42:04 2014 -0700
> Candidate for master: refs/remotes/origin/irving/snes-ex12-cleanup Fri Dec
> 13 15:24:09 2013 -0800
> Candidate for master: refs/remotes/origin/jed/log-event-lookup Thu Apr 17
> 18:39:48 2014 -0600
> Candidate for master: refs/remotes/origin/jed/mat-ptap-maij-bs Thu Apr 17
> 12:06:29 2014 -0600
> Candidate for master: refs/remotes/origin/jed/vecghostgetvalues Sat Jun 14
> 22:28:04 2014 -0500
> Candidate for master: refs/remotes/origin/jed/vecop Thu Apr 17 08:43:03
> 2014 -0600
> Candidate for master: refs/remotes/origin/karpeev/fix-ksp-pcgasm Wed Jun 4
> 06:14:36 2014 -0500
> Candidate for master: refs/remotes/origin/knepley/feature-optcontrol-mg
> Wed Jun 11 14:34:25 2014 -0500
> Candidate for master: refs/remotes/origin/madams/sr-driver4 Fri Oct 25
> 14:43:12 2013 -0400
> Candidate for master: refs/remotes/origin/mlange05/fix-gmsh-coordinates
> Tue Apr 1 10:45:39 2014 +0100
> refs/remotes/origin/paulmullowney/aijcusp-ellpack-fix Tue Aug 6 10:34:13
> 2013 -0500
> Candidate for master: refs/remotes/origin/prbrune/sf-examplefix Fri Dec 13
> 11:38:36 2013 -0600
> Candidate for master: refs/remotes/origin/prbrune/snes-ex19vtkoutput Wed
> Jul 24 10:40:02 2013 -0500
> Candidate for master: refs/remotes/origin/sarich/fix-tao-valgrind-warning
> Fri Apr 4 10:58:28 2014 -0500
> Candidate for master: refs/remotes/origin/sarich/tao-purge-dm Fri Jun 13
> 11:10:05 2014 -0500
> refs/remotes/origin/stefano_zampini/pcbddc-applytranspose Mon Nov 18
> 16:32:38 2013 +0100
> refs/remotes/origin/stefano_zampini/pcbddc-globalordering-api Tue Nov 12
> 17:04:42 2013 +0100
> refs/remotes/origin/stefano_zampini/pcbddcgraph-improved Tue Jun 3 16:44:29
> 2014 +0300
> refs/remotes/origin/stefano_zampini/pcredundant-transpose Tue Jan 7
> 14:52:15 2014 +0100
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140615/422c5361/attachment.html>
