[petsc-dev] PetscSplitReduction
    Jose E. Roman
    jroman at dsic.upv.es
    Tue Jun 10 03:01:28 CDT 2014
El 08/06/2014, a las 13:13, Jose E. Roman escribió:
> El 08/06/2014, a las 12:57, Jed Brown escribió:
>> "Jose E. Roman" <jroman at dsic.upv.es> writes:
>>> Would it be too much asking that PetscSplitReduction be available in a
>>> public header? (together with the functions PetscSplitReductionGet,
>>> PetscSplitReductionEnd, PetscSplitReductionExtend).
>> Sounds reasonable to me.  Do you want to prepare a patch?  Otherwise I
>> can do it later today.
> I would rather leave it to you since you will probably want to add manpages for the three mentioned functions.
> Thanks.
I started with this:
https://bitbucket.org/petsc/petsc/commits/e8058a0
You may want to namespace SRState and add manpages.
Jose
