[petsc-dev] gradients in DMPlexTS Riemann function
Adrian Croucher
a.croucher at auckland.ac.nz
Mon Jun 9 23:11:30 CDT 2014
hi
How would one go about implementing a Riemann function in DMPlexTS that
included a term based on the gradient of the solution?
Simple example: extending TS ex11 to include a diffusion term.
Would that be done by subtracting a gradient term from the flux in
PhysicsRiemann_Advect()- e.g. a constant diffusion coefficient
multiplied by the gradient of the solution across the interface,
calculated simply by the difference between the solution values at the
two cells, divided by the distance between their centroids?
It seems to me you would need to pass the face index into the Riemann
function, to get access to the cells supporting the face and their
centroid positions- but the way the Riemann function interface is
currently set up doesn't appear to allow for that.
Or have I got the wrong idea about how one would go about implementing this?
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
